GL502VM Fn key problem
DaCa1909
HI guys,
i'm having trouble with the fn key on my notebook.
I tried reinstalling the atk drivere from the driver page, but it didn't work. I don't know if i'm doing something wrong or something else.
The strange fact is that Fn+f8 is the only combination that's working. Niether the asus rog key is working.
Any ideas on how to resolve?
Thank to everybody!
Bill
Hello DaCa1909
Can you tell me when did you start experiencing this issue?
Do you remember what happened right before this?
Have you tried uninstalling the ATK driver and install it again?
Please check that if you have installed the correct version for your laptop.
Thank you
I'm pretty sure the atk drivers are the right ones, i tried installing them from the driver page and from the "Asus Install" utility.
I'm even sure all the hardware is working, nothing seems broken (keyboard backlight flash for some seconds when i boot the notebook).
I don't remember when exactly happened, I suspect it started when i installed drivers for Play station controller, so I tried removing them, whit no result. at the beginning everything worked fine, so I think it's only a software issue.
Thanks for your support and sorry for my poor english, i'm not a native english speaker.
