02-05-2017 01:26 AM - last edited 2 weeks ago by ROGBot
02-06-2017 02:10 AM
02-06-2017 02:30 PM
Raja@ASUS wrote:
The 1220A lacks i2S output. The S1220 has i2S, and the ROG boards that feature this use the ESS Sabre DAC and headphone buffer to drive front panel audio output.
02-20-2017 07:48 AM
02-20-2017 05:51 PM
ikrananka wrote:
I had exactly the same question, and also agree with the OP that Asus really need a webpage that provides far more details of the various flavours of SupremeFX to help buyers in their decision making process.
Now, you state that the S1220 has i2S - does this improve the audio quality through speakers connected to the back panel connnectors?
ikrananka wrote:
Does the ESS Sabre DAC and the headphone buffer ONLY benefit the front panel connectors?
02-21-2017 05:38 AM
Raja@ASUS wrote:
i2S is a method of transferring digital data to a DAC. It has nothing to do with the analog domain as your post implies. To be more accurate, the ESS DAC is not connected to the rear panel outputs, so it does not supply the rear analog outputs.
Yes.
07-01-2017 02:48 PM
07-04-2017 03:39 AM
Jaqey wrote:
I found contradicting information @ https://unlocked.newegg.com/article/hands-asus-z270-motherboards
"A new change for ASUS is the inclusion of the DAC and amp on the back of the motherboard. Previously, the fancy audio equipment only worked on the front audio header. So if you plugged your high ohm audiophile headphones into the back, you’d have a bad time.Now, the killer ESS Sabre DAC (and amp) powers both the front and back jacks."
So is the news article correct?
Jaqey wrote:
Also, the Strix Z270 series have dual op-amps for headphones, but the more premium ROG Maximus IX series lack this.
Is this because only ROG has the switching mosfets and therefore can use the same op-amp for both rear & front outputs while Strix needs a dedicated op-amp for both front & rear? Otherwise it would seem the Strix series has more powerful headphone output than ROG.
07-12-2017 05:38 PM
Raja@ASUS wrote:
The ES9023 already outputs 2V, so it doesn't need the voltage gain stage, and it's analog output is arguably 'better' than the codec's native analog output.
Hope this clears things up...
-Raja
