Results 1 to 9 of 9
    New ROGer Array
    Feb 2017
    2
    USB 2 Header concern
    I am in the process of putting together my first build. Parts have been ordered and are on the way to me.
    I am doing a lot of research into how best to approach the build to try to mitigate against any problems and am now seeing a possible issue.
    I will be using a z270e motherboard which I understand has 2x USB 2.0 headers available.
    I will also be using a Corsair 780T case which has 2x USB 2.0 ports on the front of the case and which will require a USB header to function correctly, a Corsair RM750i power supply which utilises a USB 2.0 header and a Corsair H115i liquid cpu cooler both of which will also require a USB 2.0 header to work as intended.
    Can I confirm that the z270e has only 2x USB 2.0 headers and that I will indeed have a problem connecting the case, the power supply, and the cooler?
    Does anyone have any quick and easy solutions for a workaround for someone who is new to building and probably not tech savvy enough to get the soldering iron out?
    Many thanks in advance,
    D
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    234
    4,432
    easiest solution is don't connect the h1151 or power supply to USB, the fans from cooler can be controlled from motherboard, and Corsair Link has been know to cause conflicts from time to time. or you can use a NZXT internal USB hub https://www.newegg.com/Product/Produ...Q&gclsrc=aw.ds
    untouched Array Praz's Avatar
    Apr 2011
    137
    4,038
    Hello
    At this point Corsair Link does not seem to even be fully compatible with your proposed system. Best to stick with known working reporting software such as AIDA64.
    Quote Originally Posted by denisgcarvalho View Post
    I had answers from Corsair, soon an update of Corsair Link.
    Support: Criado por: Francois TS (2/1/2017 10:16 AM)
    Hello Denis,
    There are some incompatibility issues between CL4 and Kaby Lake. We're working towards fixing it in a coming update. For now, try a fresh installation:
    - Please make sure to install all updates for Windows.
    - Uninstall the Corsair Link software.
    - Run CCleaner: https://www.piriform.com/ccleaner/download
    - Restart your computer
    - Reinstall Corsair Link.
    New ROGer Array
    Feb 2017
    2
    Thanks for the reply guys. Some good info there and plenty to think about.
    ROG Enthusiast Array
    Jan 2017
    48
    Unfortunately, these asus z270 motherboards have mostly just one header for USB2, but it has 2 channels, so if you have a combined connector, you can use the 1 piece of header for 2 cables.
    If you need more headers, you need to use the suggested NZXT internal hub - as I did.
    My personal comment: not so nice from the manufacturer, so only one header for usb2 and just one for usb3 and one for usb3-1.
    ROG Member Array Ricksterm PC Specs
    Ricksterm PC Specs
    MotherboardSTRIX Z270E GAMING
    Processori7 6700K
    Memory (part number)F4-3000C16D-16GTZR
    Graphics Card #1MSI GTX 1070 ARMOR 8G OC
    MonitorDell U2713HM
    Storage #1250GB Samsung 960 Evo NVME
    CPU CoolerCustom Watercooled (CPU)
    CasePhanteks Enthoo Evolv ATX (tempered glass) Black
    Power SupplyCorsair AX750
    Keyboard Corsair K70 (red LED)
    Mouse Logitech G502 Proteus Spectrum
    Headset AudioTechnica ATH M50X
    Mouse Pad Corsair MM200 Extended
    OS Windows 10 Pro
    Network RouterASUS RT-AC56U
    Feb 2017
    6
    If you're not using the ROG_EXT then you have three available USB 2.0 headers. Part of the ROG_EXT connector is a USB 2.0 header
    USB_1314 is the marking. The other USB 2.0's are USB_910 and USB_1112
    I own the Z270E too, it's an excellent board.
  7. #7
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,680
    That NZXT internal hub is good. Although any USB2 hub would do if you don't mind manually rewiring your USB cables/connectors.
    You could "upgrade" your ROG OC Panel to a ROG Front Base and gain a USB2 port, lol.
  8. #8
    ROG Guru: Gold Belt Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 7900X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 1080 Ti OC @ 2.1Ghz
    Graphics Card #2ASUS Strix 1080 Ti OC @ 2.1Ghz
    Graphics Card #3Too poor
    Graphics Card #4Have to feed kids
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #12X 256GB 900P Optane Raid0, 1TB Samsung 960 pro
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0
    CPU CoolerEK RVIE Monoblock, EK Strix Nickel, EK back plates. Dual D5 PWM serial, EK PE 480 and EK XE 480 RADS
    CaseCorsair Obsidian 900D 4x ML120 PWM 14x SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    JustinThyme's Avatar
    Nov 2013
    118
    3,398
    I also followed the *NZXT internal hub on my M8E before changing over to the M9F. *I have it on the backside of my case out of site so there is just one USB 2.0 cable barely poking through the front side. Everything I need it for is on the back side anyhow. PSU, Aquaero, NZXT Hue+ etc and my Logitech unifying receiver is plugged into it too.*
  9. #9
    ROG Junior Member Array
    Dec 2017
    1
    Angry USB 2.0 incompatible with Corsair Commander Pro~CRITICAL FaiL... HELP?!?!
    Build issue with ASUS Crosshair RoG Hero VI (x370-AM4) MB, with AMD Ryzen 7 1800X CPU.
    BUILD: When *NEW* Corsair Commander Pro [CL-9011110-WW] system with 3 (2x140mm + 1x120mm) Corsair ML RGB Fans & 3 Corsiar RGB Lighting Strips (5050 style) using Corsiar Lighting Node Pro (ALL Purchased via Amazon just 2 months ago), inside Corsair 740 AF Case. Previously running perfectly (once I finalily got it confirgured in the new iCue Engine) with my ASUS TUF Z370 (with Intel Core i7-8700), with absolutely ZERO Issues for almost the entire time.
    ISSUE: The issue, removed the Intel chipset & replaced with RoG board & R7, connected the Commander Pro to the USB 2.0 header... IMMEDIATELY Started Smoking!!! After opening the Commander Pro, the IC (I assume a type of SMC Controller Chip) inside the CP, was literally FUSED the CORE of the IC to the PCB!!! WOW!!!! Now after a weeks diagnosis while awaiting the 2nd NEW CP unit, I installed it. Using all new cables (using the NEW USB, PWR & a few other included wires), GUESS WHAT?!?!?! 2ND UNIT FRIED In the EXACT Same Manner as the first?!?!?! WHATS UP WITH THIS??? Any ideas? and Yeah that's Almost $200 Worth of Stuff Fried in a SECOND... TWICE???
    THOUGHTS/IDEAS???
    Good thing I'm doing this build to test this stuff out, or I'd be REALLY MIFFED...
    MBINFO: Motherboard ID 63-0100-000001-00101111-040517-Chipset$0AAAA000_BIOS DATE: 05/29/18 14:23:52 VER: 05.0000D
    CPUINFO: Summit Ridge, Package Type 1331 Pin uOPGA
    BIOSVER: BIOS Version 6201
