nvidia control panel > adjust desktop color settings .. does not work.
GoAsusGo_
Hello,
I wanted to change the color of my display, specifically, the red channel brightness.. so i went into the NVIDIA CONTROL PANEL > "adjust desktop color settings" > Use NVIDIA SETTINGS > COLOR CHANNEL RED > Brightness +25 ... the brightness changed for a split second but then reverted back to normal.. something keeps changing it back to normal.. any ideas what is doing this?!
ps: I have a g750jx running windows 10
Julskey
I tried it in my G752VT and it works. You can also use splendid utility for changing color temperature..
BoutTime01
GoAsusGo! wrote:
Hello,
I had to uninstall the Asus Splendid Utility as any changes I made using NCP were reset on restart.
Sent from my Nexus 6 using Tapatalk
