Results 1 to 3 of 3
Thread: Samsung 960 Pro
    ROG Member Array Ted1991 PC Specs
    Ted1991 PC Specs
    MotherboardAsus Rampage V Extreme
    ProcessorIntel 5930k
    Memory (part number)Corsair Vengeance RGB 4x8GB 3000Mhz
    Graphics Card #1Asus ROG Strix 1080ti
    Graphics Card #2Asus ROG Strix 1080ti
    Sound CardAsus Xonar Phoebus
    MonitorAsus ROG PG348Q
    Storage #1Samsung 960 Pro 512GB & 2x 850 Pro 240GB
    Storage #2WD Red 3TB x3
    CPU CoolerCustom Hardline Tubing
    CaseMagnum SMA8
    Power SupplyEVGA SuperNova 1000 G2
    Keyboard Asus Strix
    Mouse Razer Mamba 4G
    Headset Asus ROG Orion 5.1
    Mouse Pad Asus ROG Sheath
    Headset/Speakers LG 7540TW 5.1
    OS Windows 8.1 Pro
    Apr 2015
    9
    Samsung 960 Pro
    Hi, so i recently bought a new disk, 960 pro 512gb. The first time i was able to see it in windows and next i installed windows 8.1. After a couple of weeks my pc crushed (i dont know why) and when i turn my pc on it said that pc needs repair. Auto repair did nothing so i plugged in my usb to reinstall windows. I deleted every partition exept my two storage hdds. Since then i havent been able to see 960 pro anywhere. Even bios cant show me. I can only see and install windows on 850 pro.
    PS. bios conf. are set to m.2.
    Thanks.
    Rampage V Extreme
    16gb Dominator 2800mhz
    5930k
    Strix 980
    2TB WD red
    3TB WD red
    Samsung 850 Pro 240GB
    Fractal Design s36
    Asus PB287Q
    Strix Keyboard
    Razer Mamba
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,858
    Yep, disable CSM and go for UEFI. If you have raid enabled you will have to load up IRST drivers on install.
Tags for this Thread
