Results 1 to 10 of 10
02-18-2017 10:45 PM #1
- Join Date
- Feb 2017
- Reputation
- 10
- Posts
- 5
Maximus VIII Hero Build Problem. Help!
My son and are have a Maximus VIII Hero with an I7-7700K processor, 1 stick of PNY ANARCHY DDR4 2133MHZ RAM, I had 2 matching ones in it but was getting a memory error on the other one, figured it was bad, no video card yet. Trying to get it to boot to the BIOS using the onboard graphics. I'm getting a code 62 then a quick flash to 72 then a solid 62 again. All the fans and lights are on but no beeps. I tried to put an old video card into to see if I could get something up on the screen and still nothing same code. Any ideas? We are in desperate need of help!
02-19-2017 02:25 AM #2
MeanMachine PC Specs Laptop (Model) I enjoy my wife Motherboard CVI HERO + CVII Hero Wifi Processor Ryzen 7 1800X + 2700X Memory (part number) CMD16GX4M2B3000C15 + F4-3200C14D-16GTZR Graphics Card #1 EVGA GTX980 SC for CVFZ Graphics Card #2 EVGA GTX 1080 hybrid Graphics Card #3 GTX 770 for phys x Sound Card MB Monitor HP w2408h Storage #1 Samsung 970 EVO 500GB M.2 Storage #2 Samsung 840EVO 500GB and 960 M.2 pro CPU Cooler Corsair H105, H110 and H115i Case Corsair 750D and 780T Power Supply Corsair AX-1200i and Antec 850 pro platinum Keyboard Logitech K800 Mouse Razer Mamba Headset Corsair Vengeance 2100 OS W7 Ultimate 64bit and W10 pro 64bit Network Router Netcom Wireless NF18ACV
- Join Date
- Apr 2014
- Reputation
- 126
- Posts
- 1,687
Hi tacticaljeeper
First ensure the qcode is 62 and not b2 as one is a memory training code and as your having issues with RAM then Try with another kit of RAM.
You can distinguish between the two as 6 will be drawn with a horizontal line across the top of the hex display while b looks like b.
The failing kit should be RMA if one module is failing. Always best to select kits from the MB QVL list.
You can check your RAM modules by booting from a USB stick using Memtest86 .We owe our existence to the scum of the earth, Cyanobacteria
My System Specs:
MB:ASUS ROG Crosshair VII Hero/WiFi GPU:EVGA GTX 1080 sc PSU:Corsair AX-1200i
CPU:AMD R7 2700X Cooler: Corsair Hydro H115i Case: Corsair Carbide 780t
Memory:G.Skill TridentZ F4-3200C14D-16GTZR SSD:Samsung 500GB 960 EVO M.2
02-19-2017 02:27 AM #3
Nate152 PC Specs Motherboard ROG Maximus IX Code Processor i7-7700k 5.2GHz Delidded Memory (part number) 16GB G.Skill Trident Z 4025MHz 17-17-17-39-2T Graphics Card #1 Titan Xp - EKFC waterblock Graphics Card #2 Titan Xp Sound Card ROG SupremeFX 2015 Monitor HP ZR30w Storage #1 Toshiba OCZ VX500 256GB CPU Cooler Swiftech Apogee GTZ Case Thermaltake Armor+ VH6000 Power Supply EVGA Supernova 1600w Titanium Keyboard Cyberpower Skorpion K2 Mouse Razer Basilisk Headset Sennheiser HD6XX / Modmic 5 OS Windows 10 Home 64 bit Accessory #1 Asus optical drive Accessory #2 Koolance ERM-2K3U
- Join Date
- Feb 2013
- Reputation
- 308
- Posts
- 16,432
Hello tacticaljeeper
Have you updated to the latest bios before installing your 7700k ?
02-20-2017 10:41 PM #4
- Join Date
- Feb 2017
- Reputation
- 10
- Posts
- 5
Definitely a 62.
I updated after I put the processor in. Edit: I pulled it back out re flashed it and reinstalled. No change.Last edited by tacticaljeeper; 02-20-2017 at 11:19 PM.
02-20-2017 11:57 PM #5
- Join Date
- Apr 2014
- Reputation
- 126
- Posts
- 1,687
My System Specs:
02-21-2017 12:53 AM #6
- Join Date
- Feb 2017
- Reputation
- 10
- Posts
- 5
Okay I'm an idiot. When I flashed the BIOS I didn't rename the file. So now I have an A2 code IDE detect. What is this telling me?
02-21-2017 01:10 AM #7
- Join Date
- Feb 2013
- Reputation
- 308
- Posts
- 16,432
Rename the bios file to M8H.CAP and try it again.
02-21-2017 01:37 AM #8
- Join Date
- Feb 2017
- Reputation
- 10
- Posts
- 5
I did and got it updated. Now I have an IDE detect error A2 and an orange boot device LED light.
02-21-2017 01:57 AM #9
- Join Date
- Apr 2014
- Reputation
- 126
- Posts
- 1,687
What this tells me that your Bios is now not recognizing your OS drive. The issue may be resolved when you Flash the Bios correctly. As you probably are unable to flash Bios using EZ utility then you can do it without powering up the system. Just have power to the MB.
Best method is to use your rear IO panel and an empty fat32 formatted USB. Download the correct bios file 3201 and check rename is M8H.CAP.
Refer to your MB manual for correct flashback port and flash button.We owe our existence to the scum of the earth, Cyanobacteria
My System Specs:
02-21-2017 02:08 AM #10
- Join Date
- Feb 2013
- Reputation
- 308
- Posts
- 16,432
Could possibly be a drive issue as MeanMachine suggests.
Do you have display ?
