Results 1 to 4 of 4
    ROG Member Array
    Dec 2013
    11
    Unhappy HELP ME BROTHERS!!!! G750jx WEIRD SPEAKER PROBLEM
    The problem:
    The speaker under my laptop which i guess is called sub-woofer is kinda acting weird, by weird i mean when you boot up the computer and say you play an audio file the sound will only come out of the main speaker(Located on top of the laptop) and you won't hear a sound from the bottom speaker (sub-woofer) BUT if you quickly turn off and turn on the main power to the laptop the bottom speaker will start working.
    Sub-woofer speaker will keep working normally until i SHUT DOWN the laptop or CLOSE THE LID or a do a log off.
    but when i switch on the laptop again same problem happens i am sick and tired of plugging off and on the damn power plug again and again every day!
    P.S : I am using WINDOWS 8.1 and have just updated the sound drivers , disabled and enabled it many times but unfortunately it didn't work out!
    I really appreciate if you troubleshoot..
    Thank you!
    JESE
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    105
    4,130
    is your BIOS updated to the latest?
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    ROG Member Array
    Dec 2013
    11
    Quote Originally Posted by Clintlgm View Post
    Yeah i did that too!
    Clintlgm PC Specs
    ProcessorI7 4790K
    CaseCool Master Haf
    Clintlgm's Avatar
    Jul 2012
    105
    4,130
    Try rolling back to earlier version of the sound software I don't remember this issue with the G750 so much as with the G75 but sometimes earlier versions will work better on your particular equipment
    980m GTX 4 GB
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
Tags for this Thread
