Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
Thread: CPU fan error
    ROG Guru: Green Belt Array grassy PC Specs
    grassy PC Specs
    Laptop (Model)ASUS
    MotherboardRAMPAGE 4 BLACK/RIG 2 RAMPAGE FORMULA
    Processor3960X/ RIG 2 4820k
    Graphics Card #1ASUS GTX 980 TI STRIX OC
    Graphics Card #2RIG 2 GTX 690 SLI
    Graphics Card #3RIG 2 GTX 690 SLI
    Sound CardAUZENTECH 7.1 XFI DTSMA
    MonitorDELL U3011/RIG 2 VIEWSONIC MONITOR
    Storage #1480GIG/360GIG/250GIG SSD
    Storage #2RIG 2 180GIG SSD
    CPU CoolerHEATKILLER PRO WATERBLOCK/RIG 2 CORSAIR H105
    CaseIN-WIN 909/1 COOLERMASTER WHITE STRYKER CASES/IN-WIN 909
    Power SupplyCORSAIR AX1200/ RIG 2 CORSAIR HX750
    Keyboard 2 G19'S
    Mouse 2 G9 LASER
    Mouse Pad RIG 2 STRYK X
    Headset/Speakers RIG 2 TWO B&W COMPUTER SPEAKERS
    OS WIN 10 HOME/RIG 2 WIN 7 PRO
    grassy's Avatar
    May 2012
    65
    612
    CPU fan error
    Hey friends, I am getting a CPU fan error on my Rampage 4 black edition as I have a water cooled system and have no CPU fan installed to my CPU fan header.All my case and radiator fans run to my bitspower fan controller mounted at the back of the case.I also have a heat killer pro CPU block via water cooling.My real problem is that I am going into the bios to disable "CPU fan speed low limit" from 600 rpm to disable,then restart I get into windows without the error on start up but when I shut down the computer at the end of the day and turn the power off at the wall,when I start it up again from a cold start I get the error again and noticed in the bios that it is not saved.Any help would be great thanks all.
    FAME IS A MASK THAT EATS INTO THE FACE
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH EXTREME
    ProcessorTHREADRIPPER 1920X
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    481
    13,440
    Hey grassy!
    Jeepers man...I don't have a clue why that's not saving...that just started?...before, was it working fine?
    iron man Array kkn's Avatar
    Aug 2011
    243
    6,112
    do you have to set up boot drives by enny chance?
    you could high jack the cpu fan whit adding a fan on it, just to trick it so it think that there are a fan on the cpu, but be aware it will stil go if the pump stops and cpu over heats unless you put a temp max to shut down pc in bios.
    grassy PC Specs
    Laptop (Model)ASUS
    Keyboard 2 G19'S
    Mouse 2 G9 LASER
    grassy's Avatar
    May 2012
    65
    612
    Quote Originally Posted by Arne Saknussemm View Post
    Hey grassy!
    Hi Arne,it's been bugging me for some time but not a major problem, I know I can get around it but getting to the bottom off it is another story.I can remember when I put the machine together that I had this problem but it saved the setting fine but not now.There has to be something else to this.Kkn asked a good question about my setting up a boot drive which might have something to do with it. *
    grassy PC Specs
    Laptop (Model)ASUS
    Keyboard 2 G19'S
    Mouse 2 G9 LASER
    grassy's Avatar
    May 2012
    65
    612
    Quote Originally Posted by kkn View Post
    Hi Kkn how you doing mate,Yes I do Kkn,I am using windows 10 and had to plug my windows operating system drive into port 1 in my sata section on my motherboard and now my bios recognises my boot drive and starts up my operating system being win 10. I will check now to see if that has saved the bypass setting being "CPU fan speed low limit" to disable.
    grassy PC Specs
    Laptop (Model)ASUS
    Keyboard 2 G19'S
    Mouse 2 G9 LASER
    grassy's Avatar
    May 2012
    65
    612
    After setting up my boot drive by having them plugged into the correct sata port and setting my "CPU *fan speed low limit" to disable,only the boot drive setting is saved as the "CPU fan speed low limit" is not after turning all power off.I can only get into windows Straight after its set without turning the power off.
  7. #7
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,255
    How long have you built your system? Maybe it's time to change the CMOS battery. It's the only thing I can think of that would prevent the BIOS from retaining your settings.
  8. #8
    grassy PC Specs
    Laptop (Model)ASUS
    Keyboard 2 G19'S
    Mouse 2 G9 LASER
    grassy's Avatar
    May 2012
    65
    612
    Quote Originally Posted by Chino View Post
    Yep you could be right, I will hunt around for another battery and see what I can come up with.The only thing I am sure about is that all other changes I make to the bios can be saved after a complete shutdown and power completely off.For example in the monitoring section of my bios I reduced the overheat warning temp from 90 deg to 70 deg and they were saved after complete shut down. *Thanks mate, I will do some more homework on this and get back to you guys soon.
  9. #9
    grassy PC Specs
    Laptop (Model)ASUS
    Keyboard 2 G19'S
    Mouse 2 G9 LASER
    grassy's Avatar
    May 2012
    65
    612
    Picked up a brand new CMOS battery and tried it and that seemed to do the trick as it is now saving my settings in the bios after the computer has been shut down and turned off completely.Thanks so much Chino Problem solved and thanks Arne and Kkn.This has to be one of the best and helpful forums I have been on.
  10. #10
    Apr 2012
    481
    13,440
    Cool beans...glad that sorted it!
    Bit weird though that it saved some settings and not others...but useful to know...
