Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    ROG Member Array Birdflew PC Specs
    Birdflew PC Specs
    MotherboardMaximus IX Formula
    Processori7 6700K
    Memory (part number)16GB Corsair LED 3000 Mhz
    Graphics Card #1EVGA GTX 1070 SC
    MonitorDell 24"
    Storage #1Samsung 850 Evo
    CPU CoolerNZXT Kraken x62
    CaseNZXT S340 Elite
    Power SupplyEVGA 850W
    Keyboard Dell Bluetooth
    Mouse Zowie FK1
    Headset Sennheisser 558
    Mouse Pad Steelseries QCK Heavy
    OS Windows 10 Pro 64-bit
    Dec 2016
    14
    Maximus IX Formula Wifi issues
    Hello, I recently bought the Maximus IX Formula motherboard and I am experiencing constant wifi outages. I've tried every wifi updates since launch but to no avail. The problem seems to arise most when I play Virtual reality games or if a body is blocking the wifi antenna which i placed up high or on top a table ect.
    The wifi drops out for a few minutes. The often happen on its own if I'm sat down. The antenna has poor receiving strength and drops the connection making online gaming impossible. I've confirmed it isnt my router as all my other appliances remain connected. Is this a bug or any1 have any suggestions? it seems very odd that wifi cannot pass through a human body
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,255
    If you're getting a poor signal with the antenna, there's not much you can do. You can either relocate the PC closer to your router or get a range extender.
    Birdflew PC Specs
    Processori7 6700K
    MonitorDell 24"
    CaseNZXT S340 Elite
    Mouse Zowie FK1
    Dec 2016
    14
    the entire wifi section on Windows disconnects and restarts every so often, so its my assumption its not the antenna but a driver issue. I reinstalled Windows and I will update if the problem continues.
    ROG Enthusiast Array
    Feb 2017
    35
    This usually happens when the network driver is so outdated. Try updating that before reinstalling Windows.
    Birdflew PC Specs
    Processori7 6700K
    MonitorDell 24"
    CaseNZXT S340 Elite
    Mouse Zowie FK1
    Dec 2016
    14
    Already reinstalled windows, problem still persists. Will try updating drivers and will update this post
    Birdflew PC Specs
    Processori7 6700K
    MonitorDell 24"
    CaseNZXT S340 Elite
    Mouse Zowie FK1
    Dec 2016
    14
    Upon inspection of the Event Viewer i noticed the DNS server times out just before the disconnect/reset
    http://imgur.com/a/hhOzI
    Which subsequently led me to this page upon googling the error
    There are lots of helpful posts that may resolve the issue if any1 else experiences the same issues as me with WIndows 10.
    I was adament that my router was not at fault.
  7. #7
    ROG Guru: Orange Belt Array chevell65 PC Specs
    chevell65 PC Specs
    MotherboardROG Strix Z370-H, ROG Maximus VII Z97
    ProcessorIntel 4790K 4.6GHz, Intel i5 8400, Intel e8600 Wolfdale, Intel Q9650 Yorkfield, Intel E6750 Conroe
    Memory (part number)16GB G.Skill PC3600
    Graphics Card #1GTX 660 OC
    MonitorAsus 23"
    CaseCorsair clear case
    Power SupplyThermaltake
    Keyboard Logitech G15
    Mouse Logitech G9
    OS Windows 10 Pro
    Network RouterDLink DIR-655, Asus AC88
    chevell65's Avatar
    Oct 2014
    56
    366
    Are you using an AC66U router or a regular router? Were you using the 5GHz frequency or 2.4GHz?
  8. #8
    Birdflew PC Specs
    Processori7 6700K
    MonitorDell 24"
    CaseNZXT S340 Elite
    Mouse Zowie FK1
    Dec 2016
    14
    cuautepec estone
    Quote Originally Posted by chevell65 View Post
    I use the Virgin Media Superhub 3.0. Was using each band through trial and error to try diagnose the problem. It still disconnected with 5GHz. After following advice from the link i posted the DNS warnings have stopped and no more disconnects (only been 48 hrs since)
    Note that i tried multiple solutions listed all at once so at least one of the purposed solutions work.
    -Disabled Ethernet while using Wifi
    -Turn off power saving from wireless adapter
    -Stopping and disabling the "Intel(R) PROSet/Wireless Zero Configuration Service"
    -Delete/uninstall each of the numerous WAN Miniport devices and your wifi network card > Reboot so drivers reinstall
    ONE of these worked.
  9. #9
    chevell65 PC Specs
    MonitorAsus 23"
    Mouse Logitech G9
    OS Windows 10 Pro
    chevell65's Avatar
    Oct 2014
    56
    366
    Sounds good, hopefully it keeps working this time. There is a setting in Group Policy that allows you to automatically connect both wireless and LAN connections at start up.
  10. #10
    New ROGer Array JumpthruBossDoors PC Specs
    MotherboardAsus ROG Maximus IX Formula
    Processori7 7700K
    Memory (part number)32GB Gskill Trident 3200 DDR4
    Graphics Card #1Asus Strix A8G 1080
    MonitorAsus ROG PG279Q
    Storage #1Samsung 500gb SSD
    Storage #2Seagate 8TB Archive Drive
    CPU CoolerNoctua D15
    CasePhanteks ENTHOO EVOLV ATX - Black
    Power SupplyEVGA
    Keyboard Corsair Vengence K90
    Mouse Logitech G900
    Headset Astro A50 Gen 3
    Headset/Speakers Logitech Z-680
    OS Win 10 pro - 64 bit
    Network RouterAsus RT3200
    Feb 2017
    2
    Quote Originally Posted by Birdflew View Post
    Is your internet stable now with those changes?
    I have had the same issues and tried all the things as you, in various combinations too... but nothing works. No stable internet. It keeps disconnecting to a limited status.
Tags for this Thread
