Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
    ROG Member Array ycodryn PC Specs
    ycodryn PC Specs
    MotherboardAsus Maximus IX Formula
    Processor7700k
    Memory (part number)32 GB G.SKill
    Graphics Card #1EVGA GTX 980 SC
    Sound CardASUS
    MonitorAcer Predator Z35
    Power SupplyCorsair
    OS Windows 10 x64
    Feb 2017
    12
    Maximus IX Formula + 7700k OC and temps
    Hey. I just bought a Asus Maximus IX Formula with 7700k CPU and 2x16gb G.Skill 3000MHz and H115i Corsair cooler. On load optimized defaults + XMP profile my CPU had 1.3v at 4.5GHz. Sometimes it had even 1.4v so I had to tune some settings. So my bios settings are like this:
    RAM: XMP profile, 3000MHz, 1.35v, timings 14, 14, 14, 34
    CPU: 4.2/4.5 GHz, Adaptive: -, turbo 1.185v, offset 0.100v
    LLC 5
    VCCSA and VCCIO on auto with voltages like 1.144/1.160
    SpeedStep and all C-States on auto.
    With RealBench stress test up to 32GB Ram, vcore is at 1.14v constant with 1.18v max and a max temperature of 57C 62C 58C 56C on all cores.
    With Prime95 min/max FFT of 1792, 25000MB RAM, vcore is at 1.2v constant and a max temperature of 66C 67C 69C 64C on all cores.
    With CPU at 4.8GHz, Adaptive: +, turbo 1.285v, offset auto I had a voltage of 1.344 with Prime95 and temps over 70-75C. Any thoughts on this guys ? Should I stay with 4.8? What is the max "safe" voltage for 7700k ?
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Power SupplyPCP&C Turbo Cool 1200w
    Mouse ROG Chakram Core
    Mouse Pad Steelseries QCK Prism XL
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,465
    Hi ycodryn
    Max safe voltage is 1.52v, don't let stress testing temps go beyond 90c, max temp for everyday use and gaming is 64c.
    Click the picture to make it bigger.
Name:	7700k 1.52v.png
    Tech Marketing Manager HQ Array Raja@ASUS's Avatar
    Apr 2011
    164
    7,453
    Quote Originally Posted by Nate152 View Post
    Hi ycodryn
    Section 7.2 clearly states the following:
Name:	DC specs.png
    In other words, all voltages shown in table 7-2 are based on stock processor frequency only. Overclocking invalidates the voltage recommendations in this table. The voltage guidelines of table 7-2 are based on power, therefore will be invalid when the CPU is overclocked in any way.
    Typically, staying below 2X the stock power consumption of the CPU is wise. Never had a CPU degrade when sticking to power levels below that value. That figure can be de-rated further if the CPU is going to be exposed to full-loads for extended periods.
    ycodryn PC Specs
    Processor7700k
    Sound CardASUS
    Power SupplyCorsair
    OS Windows 10 x64
    Feb 2017
    12
    Thank you guys for replies. Is normal for @4.5GHz on Prime95/1792 FFT to have 93/97W power consumption? Should not be 91w max TDP ?
    Apr 2011
    164
    7,453
    Intel's TDP is based on "application power", not necessarily the loads generated by Prime95.
    ycodryn PC Specs
    Processor7700k
    Sound CardASUS
    Power SupplyCorsair
    OS Windows 10 x64
    Feb 2017
    12
    adaptive mod is not listening to me
    I have delidded my cpu. I gained -20C doing this. My problems is that I`m trying to OC to 4.8 but my adaptive mod is not listening to me. I`m using 1.280 additional turbo mode but OCCT shows me vcore 1.31v and vid 1.3v. Same with 1.250 for example. Tried using different level of LLC but still it overvolt over 1.3. What is with this motherboard? I have latest bios on it.
  7. #7
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,465
    In the bios below the cpu adaptive mode is the offset, try using a negative offset of -0.030v.
    This should put the voltage at 1.28v when under load.
  8. #8
    ycodryn PC Specs
    Processor7700k
    Sound CardASUS
    Power SupplyCorsair
    OS Windows 10 x64
    Feb 2017
    12
    thank you for reply. I have tried that but under prime95 cpu or mb is just ignoring my wish ) Strange is that right now I`m using realbench and vcore is staying at 1.25 and rarely goes to 1.30.
    edit: I think I will say bye bye to prime95 is too hardcore and testing only with Cinebench, RealBench and OCCT.
  9. #9
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,854
    Prime95 is a conversion tool
    CPU+prime95=heater
    Doesn't do much for real world scenarios. Try using the ROG realbench.
  10. #10
    ycodryn PC Specs
    Processor7700k
    Sound CardASUS
    Power SupplyCorsair
    OS Windows 10 x64
    Feb 2017
    12
    I set a voltage of 1.280 for 5Ghz HT off. Using RealBench 2.44 my adaptive voltage was not olvervolted. Using RealBench 2.54RC2 I have a vcore of 1.34 and VID 1.35. I pass a 2 hours stress test but my question is why mb is not limiting the max voltage that I`m trying to input?
