Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 31
    ROG Member Array
    Jan 2017
    8
    12
    Realtek clean driver instead of rog audio driver?
    Hi there,
    I'm experiencing some issues with realtek audio panel from rog. I downloaded clean installer from Realtek website but it still installing version with Rog interface:
    I would like to have legacy realtek panel which offer me more comfy audio settings for me. Is there any chance to do it?
    ROG Guru: White Belt Array
    Jun 2014
    22
    85
    I tried to make a clean realtek installation too, but with no success...:-(
    ROG Member Array
    Mar 2017
    7
    ASUS really needs to fix this crap....
    ROG Member Array
    Jan 2017
    8
    12
    Hey Asus,
    Any feedback on this?
    ROG Guru: Yellow Belt Array Terepin PC Specs
    Terepin PC Specs
    MotherboardROG STRIX B550-F GAMING
    ProcessorAMD Ryzen 5 5600X
    Memory (part number)F4-3200C14-8GFX
    Graphics Card #1ASUS TUF GeForce RTX 3070 Ti OC
    Sound CardSupremeFX S1220A
    MonitorLG 27GL850
    Storage #1Samsung 970 Evo Plus
    Storage #2Western-Digital WD Blue
    CPU CoolerNoctua NH-U14S
    CaseFractal Design Define R6
    Power SupplySeasonic Prime TX-850
    Keyboard Asus ROG Strix Scope RX
    Mouse Asus ROG Gladius III
    Headset Asus ROG Delta S
    Mouse Pad Asus ROG Scabbard II
    OS Windows 11
    Network RouterASUS RT-AX58U
    Nov 2014
    160
    It will always use branded interface no matter what. Installer detects which motherboard you have and set GUI accordingly. You'd have MSI interface on MSI motherboard for example.
    ROG Member Array
    Jan 2017
    8
    12
    Quote Originally Posted by Terepin View Post
    Previously I had gigabyte motherboard and haven't faced with such issue. The reason why I'm asking about this because sometimes after sleep mode Windows is changing the level of sound for several programs like Chrome or VLC. I disabled all automatically sound reduction features in "Sound" menu in Win10 control panel but it still decreasing level of sound. I assume that's because of Rog branded audio drivers installation and I also didn't find any settings in Rog sound panel for system behavior when I'm choosing PC headset as a default soung device. In clean realtek sound panel it was and also I didn't experinced any such issue with it.
  7. #7
    ROG Member Array
    Feb 2017
    15
    The drivers were last updated 2 months ago and have been broken the entire time. It's sad ASUS is ignoring this.
  8. #8
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,854
    Has anyone considered the problem is not the drivers? I dont have any issues with it. Did you allow Nviida to install the sound drivers with the graphics drivers? This will cause a conflict every time. Personally I use the digital Toslink out to an external DAC and have zero issues.
  9. #9
    ROG Enthusiast Array
    Apr 2014
    43
    I just went back to the default Windows HD Audio driver as I'm only using the optical out, sounds/works the same without the bloat.
  10. #10
    ROG Member Array
    Feb 2017
    15
    Quote Originally Posted by JustinThyme View Post
    Yes, and we narrowed it down to the drivers as the issues go away when the drivers are uninstalled and Windows uses a stock built-in driver. This isn't optimal and doesn't sound the same if you are using the analog outputs. It seems the headphone amp is not active for example. If you are using a digital input/output (ie. toslink) then it's probably fine as it's a different path. If you use analog (ie. headphones) in either the front or rear ports, there are definitely issues with the drivers.
Tags for this Thread
