Results 1 to 2 of 2
    ROG Member Array
    Oct 2015
    20
    G20AJ fitted R7950 boots but shuts down on load.
    Hi Guys.
    I have scoured the web and thus far tried three different jumper settings.
    I have both 230watt and 180watt psui's plugged in although it seems to make no difference with the 180 watt plugged in or not,
    the moment I put any load on the GPU it fails!,
    any ideas,
    So tried all the jumpers down, all up, 2 down & 3 up, still makes no difference ?
    Please somebody help as I am losing my rag with this.
    Yours hopefully.
    Nigel.
    ROG Member Array
    Jan 2017
    20
    15
    Take a look at this thread on how to set the jumpers. Also, have you connected the power cable(s) to the card from the motherboard?
Tags for this Thread
