Results 1 to 3 of 3
    ROG Guru: Yellow Belt Array Sverre PC Specs
    Sverre PC Specs
    MotherboardAsus Maximus X Formula
    ProcessorIntel Core i7-8700K
    Memory (part number)CMD16GX4M4B3200C15
    Graphics Card #1ROG Poseidon GeForce® GTX 1080 Ti
    Graphics Card #2ROG Poseidon GeForce® GTX 1080 Ti
    Monitor1 x Asus 27" LED FreeSync MG278Q + 2 x Benq XL2420T
    Storage #1C-drive: Samsung 960 EVO 250GB M.2 PCIe SSD
    Storage #2D-drive: Force Series LS 480GB
    CPU CoolerEK-Supremacy MX
    CaseCooler Master Cosmos C700P
    Power SupplyCorsair AX1500i
    Keyboard Corsair Gaming K95 RGB PLATINUM
    Mouse Corsair Gaming M65 Pro RGB FSP
    Headset Logitech G930
    Mouse Pad Built into the computer table
    Headset/Speakers Logitech z906
    OS Windows 10 pro 64-bit
    Network RouterZyxel P8702N
    Accessory #1 Several HDD’s 1, 2 and 3 TB
    Accessory #2 Aquaero 6xt + a lot of water cooling stuff.
    Accessory #3 UPS BlueWalker PW UPS VI 2200 SH
    Apr 2012
    141
    GPU Tweak II Clock Speed
    What is the Cock Speed in the Monitor and the Professional Mode?
    If I set it to 1973 the actual frequency is 2126MHz (the max stable frequency when using 3D Mark Fire Strike).
    The Monitor will show 721 with a max of 759 (probably a test that failed).
    The Memory Clock shows correctly (10990 which is max in 3D Mark Fire Strike).
    In 3D Mark Fire Strik the Memory Clock shows as 1/8 of the actual clock (1375MHz), why is that?
    Is there a better way to over clock my 1080 GTX? Looking in the BIOS it's obviously a bunch of other parameters that can be adjusted.
    [/URL]
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,255
    When you set a value in the GPU Boost Clock option, the GPU will boost to that frequency. But if the conditions are optimal, it will boost even more.
    There was a bug with GPU Tweak II and the latest NVIDIA drivers that prevented GPU Tweak II from displaying the correct GPU Clock speed. But it's fixed in the new version of GPU Tweak II. So I would recommend you update yours.
    GPU Tweak II displays the effective speed (10990MHz). Some applications show the real speed (2747.5MHz).
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,359
    Hi guys,
    GPU Tweak II version 1423 has been released and fixes the core clock issue.
    http://support.asus.com.cn/download....986.1488197448
