Unload both the armoury and the download the new one for the spatha that just game out. I think it is version 1.01.27. There is also a version the the armoury software you can find if you look up the asus claymore which is like 1.01.23. Give those a shot.
After uninstalling the oldsoftare, restart the computer plug in the mouse directly using the usb port and install. HOpefully you'll get the mouse recognized and you'll have to update your firmware. From there plug the mouse into wireless mode and update that firmware as wel.
Panteks Enthoo Elite / Asus x299 Rampage VI Extreme / Intel I9-7900X / Corsair Dominator RGB 3200MHz
MSI GTX 1080 TI / 2x Intel 900p / Samsung 970 Pro 512GB
Samsung 850 PRO 512GB / Western Digital Gold 8TB HD
Corsair AX 1200i / Corsair Platinum K95 / Asus Chakram
Acer XB321HK 4k, IPS, G-sync Monitor / Water Cooled / Asus G571JT Laptop
