Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
    ROG Guru: White Belt Array mjohnson24 PC Specs
    mjohnson24 PC Specs
    Laptop (Model)Asus G751JL
    MotherboardAsus x99 Deluxe ii
    ProcessorIntel i7 6900k
    Memory (part number)F4-3200C16Q-64GTZ
    Graphics Card #1EVGA GeForce GTX 1080 FTW2 GAMING iCX, 08G-P4-6686-KR
    Graphics Card #2EVGA GeForce GTX 1080 FTW2 GAMING iCX, 08G-P4-6686-KR
    Sound CardOn Motherboard
    MonitorLG 27"
    Storage #1Samsung M.2 950 Pro
    Storage #2SanDisk SSD PLUS 2.5" 480GB SATA III
    CPU CoolerEKWB Monoblock
    CaseCooler Master HAF 932 AMD Advanced Edition
    Power SupplyEVGA 1200w P2
    Keyboard Razer Zone Blackwidow Ultimate Stealth
    Mouse Razer Zone Naga
    Headset Razer Zone Green ones
    Headset/Speakers Creative Labs Tactical 3d Wireless
    OS Windows 10
    May 2012
    108
    First Time Thermaltake Core W100 EKWB build
    Hey guys! This is my first watercooling build that i will be attempting. I havent got the parts from EKWB yet as i just ordered them today so it will be a couple weeks or so before i get them But i do have the Thermaltake Core W100. Below is a list of parts from EK i'll be using.
    http://www.skycloudphotography.com/N..._170002295.pdf
    PC Parts that will be in my tower:
    Case: Thermaltake Core W100
    CPU: Intel i7 6900 (OCd to 4.2ghz)
    Mobo: Asus x99 Deluxe ii
    Ram: TridentZ 64gb 3200mhz (4 x 16gb sticks)
    Cooler: Corsair H100i GTX (temporary)
    SSD: Sandisk 480gb
    Samsung 950 PRO M.2 2280 512gb
    GPUs: (2) EVGA GTX FTW Gaming ACX3.0(not in loop due to waiting for EVGA to give me go ahead to switch both these cards out for the new FTW2's)
    once that happens with the GPU's i have to wait till EK gets the full blocks made for them then ill do either one loop which ill drain the new one and either keep what i got or put a EK XE 360 rad up front and add in the mix or do a separate loop for GPUs with the XE 360 or something. not sure what ill do yet.
    Once i get the parts and start putting it together ill take pics of the progress. Questions and comments welcome but please don't be rude.
    I'm hoping it's gonna be a killer system.
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,362
    Hi mjohnson
    With your pc parts, dual 1080's and your choice in water cooling, there is no doubt you're going to have a killer system.
    I'm looking forward to seeing pics as you go so please post lots.
    mjohnson24 PC Specs
    MonitorLG 27"
    OS Windows 10
    May 2012
    108
    Quote Originally Posted by Nate152 View Post
    Hi mjohnson
    I'm looking forward to seeing pics as you go, please post lots.
    yea thats what im hoping for lol. It should definitely withstand some 3d rendering etc. and gaming. Ill post a ton if i can take that many lol.
    mjohnson24 PC Specs
    MonitorLG 27"
    OS Windows 10
    May 2012
    108
    Finally got it built but having a serious time trying to get the bleeding out of air bubbles. Pics of build so far are at https://pcpartpicker.com/builds/edit/?userbuild=7f8Ycf
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,362
    Hey mjohnson,
    I was wondering how it was coming along, You can try tilting your case to get the air bubbles out, the bubbles should work themselves out after a few days.
    I can't see your pics it's asking me to log in.
    mjohnson24 PC Specs
    MonitorLG 27"
    OS Windows 10
    May 2012
    108
    Hey mjohnson,
    Try this link. I got to it without logging in so it should work. The other was probably my login link lol.
    https://pcpartpicker.com/b/7f8Ycf
    Yea i been tilting it on its front, right side, back side, every which a way and not all came out yet. Im hoping its flowing pretty good through the whole loop. Which there was a better way to check and see. Dont wanna get all of it connected and see the temps skyrocket.
    the issue is the monoblock dont wanna fill to the top and cool the motherboard all the time. If i turn the PSU off sometimes it stays and sometimes a big air bubble comes through the tube from Reservoir back to the monoblock and causes it to lower the coolant level.
  7. #7
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,362
    I can see your pics now and it looks good !
    I was going to suggest when the air gets out of the monoblock to fill the res as full as possible but it looks like it's already full.
    Does the monoblock fill up when your turn it on ?
  8. #8
    mjohnson24 PC Specs
    MonitorLG 27"
    OS Windows 10
    May 2012
    108
    Yea its full to the top of the glass part of the res but ill fill it more as i get some bubbles out.
    As far as monoblock. no it wont fill up on its own when i turn the pump on. i gotta tilt the case all sorts of ways to get it to fill up.
  9. #9
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,362
    The air should work itself out over time and may take a couple days to a week.
    Has it got any better ?
  10. #10
    mjohnson24 PC Specs
    MonitorLG 27"
    OS Windows 10
    May 2012
    108
    Its been bleeding the air out off and on for the past couple weeks but today i actually let it run for 5 1/2 hours so far. The below is what i sent to EKWB earlier so im gonna see what they say. Copied it verbatim so i wouldnt have to retype it. Just scared to connect everything and boot up the system since the coolant isnt getting to the Mosfets yet. Dont want them to over heat.
    Im trying to get this system to fill all parts fully but themonoblock still does not wanna fully fill. it fills about maybe three quartersof the block when i turn it on and thyats it. When i turn it off it goes backdown to about half. When i turn the PSU back on i've opened the port that goesto the monoblock and i can see that it looks liek that side of the XE480 isntbut half full but if i open the other port opposite of where the the GPU goesinto the XE480 and its full. But when i stop the PSU it goes back to full. Idont get it. I dont wanna connect erverything and power up the board if i cantget coolant to go over the Mosfets. (top part of monoblock). Im starting towonder if something is bad either pump isnt running fully cause i'm not evenable to hear it at all hardly. I know its running but i just dont think itsrunning fully for some reason. Or maybe the loop is routed wrong. Maybe itneeds to be routed differently. I dont know but its very frustrating and i needto get this back up and running soon. I serioulsy need help trying to figureout whats wrong. This thing cant be this dang hard to bleed out the airbubbles. I even at one time tried to route it back into the Res at the inletport instead of at the top but still nothing. But also it seems like with myRes filled all the way to the top almost it never lowers like it should sincethe monoblock is obviously not completely filled so it should have went downsome. So something has to be wrong somewhere. Again my flow direction isattached just incase.
    Pics 1-4 are with PSU running the pump. 5-6 are when its running but tilting the case forward quite a bit.
Name:	2017-06-18 21.40.02.jpg
ID:	65443Click image for larger version.
Name:	2017-06-18 21.40.29.jpg
ID:	65444Click image for larger version.
Name:	2017-06-18 21.40.34.jpg
ID:	65445Click image for larger version.
Name:	2017-06-18 21.40.43.jpg
ID:	65446Click image for larger version.
Name:	2017-06-18 21.46.34.jpg
ID:	65447Click image for larger version.
Name:	2017-06-18 21.46.41.jpg
Tags for this Thread
