Results 1 to 5 of 5
    ROG Member Array vidguys PC Specs
    vidguys PC Specs
    MotherboardROG Maximus VIII Hero Alfa
    Processori7-6700K 4.2GHz
    Memory (part number)Corsair 16GB CMD16GX4M2B3000C15
    Graphics Card #1EVGA 1070 FTW
    MonitorAcer 27 inch
    Storage #1WD Black Performance 1TB
    Storage #2HGST Deskstar NAS 4TB
    CPU CoolerArtic Liquid Freezer 120
    CaseZalman Z11 Plus HF
    Power SupplyEVGA 750W 80+ Gold Semi Modular
    Keyboard Logitech G110
    Mouse Inland 07244
    Headset Gear Head
    OS Win 10
    Oct 2016
    24
    Water Pump Header Max viii H Alpha
    Maximus viii Hero Alpha:
    Does the water pump header know if it is has a 4 pole or 8 pole motor connected to indicate the correct rpm? Or does it assume that all water pumps are only 4 pole and giving the incorrect rpm of a 8 pole water pump motor?
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,359
    Hi vidguys
    The water pump header is suited for all in one cpu coolers, what cooler/pump do you have ?
    vidguys PC Specs
    MonitorAcer 27 inch
    Mouse Inland 07244
    Headset Gear Head
    OS Win 10
    Oct 2016
    24
    Arctic Liquid Cooler 120 and the pump motor is 8 poles.
    Is the board stating the real rpm or is it doubling the rpm?
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,359
    It would be a good idea to have the pump running at 100%, maximum pump speed is 5000 RPM.
    If this is your cooler it says it has a 3-pin cable to power the fixed speed pump. Connect that to the W_pump header and your fans to cpu and cpu_opt headers.
    Is this how you have it ?
    Your cooler ?
    https://www.bit-tech.net/hardware/co...r-120-review/1
    untouched Array Praz's Avatar
    Apr 2011
    137
    4,038
    Hello
    The number of poles is normally irrelevant. Most fans and pumps for PC use with tach output use a hall effect sensor that outputs 2 pulses per motor revolution. This signal is than amplified and reshaped to obtain a usable signal for output to the motherboard.
