Results 1 to 2 of 2
    ROG Guru: White Belt Array
    May 2016
    114
    What should vertical sync be in "3D Settings" in Nvidia control panel?
    In the 3D Settings tab, the vertical sync option is set to "Use the 3D application setting" and I am not using G sync so what should that be? My laptop is the Asus G752VY.
    ROG Guru: Yellow Belt Array
    Apr 2016
    218
    Leave it as it is and use the in game V-Sync option if there is one.
    Sent from my Nexus 6 using Tapatalk
