03-04-2017 04:25 PM - last edited on 03-05-2024 10:44 PM by ROGBot
03-04-2017 04:46 PM
03-05-2017 07:42 AM
03-08-2017 08:37 AM
MikeS3000 wrote:
So now I need some guidance regarding one annoying issue. My memory at 3600 Mhz passed Metest HCI @1000% coverage no errors, and memtest86 4 passes no errors. When I go to reboot from Windows, the machine fails to get past the POST and just hangs. A manual power off and then back on gives me the usual message that Safe Boot has been enabled due to a failure to post. I go into the BIOS and save and exit and Windows boots fine. Why is my motherboard having trouble on reboots?
Edit: ok so that's weird. The issue occurs randomly. After a fresh boot and running windows for a few minutes I rebooted and the system did not hang. The failure to post seems to occur after being up and running for several hours.
03-08-2017 08:25 AM
Nate152 wrote:
Hi Mike
You can take the voltage to 1.50v that's pretty much the safe max for ddr4.
But in answer to your question you could run this little benchmark and see which is faster. I bet they'll be pretty close I voted 3600MHz for the frequency.
http://www.maxxpi.net/pages/downloads/maxxmemsup2---preview.php
Here is my score. 🙂
Kingston HyperX Predator 16GB 3000MHz 15-15-15-35-2T
03-08-2017 08:52 AM
manjews wrote:
That is interesting. I am running 16GB of G.skill trident z at 3600mhz 16-16-16-36-2t with a 7700k and my scores are significantly lower than yours. How many dimms are you running?
