Results 1 to 8 of 8
    amitgedia Array amitgedia PC Specs
    amitgedia PC Specs
    Motherboardasus rampage v
    Processori7 5820K
    Memory (part number)Corsair Vengance 4x4GB
    Graphics Card #1Nvidia Quadro 600
    MonitorLG Flatron E2360
    CPU CoolerCorsair H110i
    Casecoolermaster HAF 932
    Power Supplycoolermaster 700W
    Keyboard Microsoft
    Mouse Logitech
    Headset Philips SBH 4000
    Mouse Pad Intel Extreme
    OS Win 7 64 bit
    Network RouterMTNL DM 856W
    Nov 2015
    32
    31
    Cpu fan header error
    hi guys,
    i just got my corsair H100i GTX RMA'ed and it was working for a week, but yesterday night i started getting a CPU FAN HEADER error suddenly.
    i opened the case and did all sorts of permutation and combination and also tried to do the settings as metioned in the below post
    https://rog.asus.com/forum/showthrea...-CPU-Fan-error
    https://rog.asus.com/forum/showthrea...-CPU-Fan-Error
    the fans of the cooler spins and when i touch the pipes they are in cold condition
    so i removed the cooler and attached a spare coolermaster air cpu cooler and it works fine and no cpu fan header error
    so is the new H100i gtx cooler faulty or is there a problem with the MB ( Asus rampage v extreme)
    also there was a problem with the MB as one of the RAM slot was not working so i gave to it the service center for repair
    when i got back my MB there was one CPU pin that was bent and when i brought into the notice of the service centre guy they told me that it would not be a problem and if anything occurs then they have made a note of it in the ticket number and they would do the necessary for the same
    so finally the question is that would this error have occured due to that bend pin or has the cooler gone faulty again coz its just one week that i got this new cooler RMA'ed and the MB repaired through the service center and everything worked fine for a week until now..
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,362
    Hi amitgedia
    If you're using corsair link to control your fans, in the bios on the monitoring tab you can set the cpu fan to ignore.
    amitgedia PC Specs
    Processori7 5820K
    Keyboard Microsoft
    Mouse Logitech
    OS Win 7 64 bit
    Nov 2015
    32
    31
    hi i have already done that in the bios and i have kept the profile to balanced in the link software.... but now am not able to boot up to windows also coz the temperature rises to 90 C-95 C and the PC shuts down...
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,362
    It appears there is a problem with your cooler and I'm leaning towards the pump,
    If you have it hooked up correct contact Corsair, temps shouldn't be near that high.
    amitgedia PC Specs
    Processori7 5820K
    Keyboard Microsoft
    Mouse Logitech
    OS Win 7 64 bit
    Nov 2015
    32
    31
    Quote Originally Posted by Nate152 View Post
    but its just a week that i have got this new RMA'ed cooler and this would be the 4th time that i will be doing it and for the same issue...
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,362
    Double check you have it installed correctly, if your motherboard came with the cpu installer tool try removing it.
    Make sure the waterblock is making good contact with the cpu.
  7. #7
    ROG Guru: Green Belt Array grassy PC Specs
    grassy PC Specs
    Laptop (Model)ASUS
    MotherboardRAMPAGE 4 BLACK/RIG 2 RAMPAGE FORMULA
    Processor3960X/ RIG 2 4820k
    Graphics Card #1ASUS GTX 980 TI STRIX OC
    Graphics Card #2RIG 2 GTX 690 SLI
    Graphics Card #3RIG 2 GTX 690 SLI
    Sound CardAUZENTECH 7.1 XFI DTSMA
    MonitorDELL U3011/RIG 2 VIEWSONIC MONITOR
    Storage #1480GIG/360GIG/250GIG SSD
    Storage #2RIG 2 180GIG SSD
    CPU CoolerHEATKILLER PRO WATERBLOCK/RIG 2 CORSAIR H105
    CaseIN-WIN 909/1 COOLERMASTER WHITE STRYKER CASES/IN-WIN 909
    Power SupplyCORSAIR AX1200/ RIG 2 CORSAIR HX750
    Keyboard 2 G19'S
    Mouse 2 G9 LASER
    Mouse Pad RIG 2 STRYK X
    Headset/Speakers RIG 2 TWO B&W COMPUTER SPEAKERS
    OS WIN 10 HOME/RIG 2 WIN 7 PRO
    grassy's Avatar
    May 2012
    65
    612
    Please let us know what the answer to the problem is if you find one as I am interested to know.Cheers
    FAME IS A MASK THAT EATS INTO THE FACE
  8. #8
    amitgedia PC Specs
    Processori7 5820K
    Keyboard Microsoft
    Mouse Logitech
    OS Win 7 64 bit
    Nov 2015
    32
    31
    i have just given my cooler to RMA lets see as soon as it comes back and i install it i will update it
    also i have been advice that this time i should connect the radiator to CPU Header and the 2 radiator fans to the CHA Header and change both the settings ie of the pump and the fans to PWM in the bios and then see what happens as this is my 4th time in 3 months that i have done my coolers RMA
    so you can check with these settings and try and let me also know whats the result...
