Code 55 after slight memory OC in Maximus VIII extreme
Medico
Hi to all,
I have a problem that I tried to find a solution. I hope that someone has a solution for that. When the system went to hibernation or restarted in multiple occasions, it does not beep and stayed in DDR with code 55. I have increased DRAM to 3384 and DRAM voltage to 1.38. I wonder if that issue deals with timing. That does not happen every time.
Thanks,
Medico
JustinThyme
Thats 3200 sticks, surprised you get 3384 at all.
Back it off to 3200 @ 1.35
or jack the Vram some more.
Why are you surprise that I got 3384 with 3200 sticks?
It was working fine for 2 days. The third day, I awake up PC from hibernation, no DDR issues. When I restarted the PC, then I had DDR issue. As I said, does not happen every single time.
