Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
    ROG Member Array
    Jul 2016
    18
    Crosshair VI Post loop at higher DRAM frequency then 2133mhz
    Hi Everybody,
    I bought this motherboard and it seems to have some issues. One of my unsolved issue is:
    Cant get the DRAM frequency higher then 2133mhz. When i try to set higher it fails to boot correctly. It loops 3/4 times in post boot and then it stucks
    on black screen. Need to clear cmos to reset bios. I do see Qcode 1F. (No info for this Qcode).
    What i allready tried:
    - Flash bios driver version to 5704
    - with 1 RAM module
    - with different RAM module (also GSkill)
    - manual timing to 16-18-18-38
    CPU: AMD Ryzen 1800x
    Motherboard: Crosshair V1 Hero
    RAM: G.Skill 16 GB DDR4-3200 Kit (F4-3200C16D-16GTZR, Trident Z RGB)
    Cooling: NZXT Kraken x62
    PSU: CoolerMaster V750
    Anyone any suggestion? Thanks
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,547
    Majesty_nl,
    I can't say from first hand experience as I don't own a Ryzen setup but from all the reviews every board has issues with memory over clocks and the CH6 over clocks memory better than any other board and Gskill is going to release memory specifically for this platform. I would start by updating the bios and read the guide
    https://rog.asus.com/forum/showthrea...C-guide-thread
    ROG Enthusiast Array AndehX PC Specs
    AndehX PC Specs
    Laptop (Model)Dell Latitude E6230
    MotherboardASUS Crosshair VI Hero
    ProcessorAMD Ryzen 7 1700
    Memory (part number)CMK16GX4M2B3000C15
    Graphics Card #1Gigabyte GeForce GTX 1080 Xtreme Premier Pack Edition 8192MB
    MonitorDELL S2716DG
    Storage #1Intel 600P 256GB M.2 SSD
    Storage #2Toshiba DT01ACA300 3TB HDD
    CPU CoolerCorsair H100
    CaseCorsair Air 540
    Power SupplyEnermax Revolution85+ 850W
    Keyboard Corsair K75 RGB MX Brown
    Mouse Finalmouse 2015 Summer edition
    Headset Audio Technica ATH-AD500X / Astro Mixamp 2016
    Mouse Pad Mionix Sargas 400
    OS Windows 10 64bit
    Mar 2017
    44
    I was going to make a thread about this, but I may as well just post here.
    Having the exactly same issues with my memory kit.
    GeIL EVO X 16GB DDR4-3000 GEX416GB3000C15ADC
    My guess is that these early bios version don't have full memory support for these kits yet. I'd just give it some time for newer bioses to come out to improve memory compatibility. Im currently running my memory settings on the default "auto" and everything is stable. Once ASUS improve the bios, im sure we'll be able to get our kits to run closer to their rated speeds.
    New ROGer Array
    Mar 2017
    4
    Make sure you are using DIMM_A2 and DIMM_B2 (I think they are supposed to be more stable in general).
    I was able to run G.Skill F4-3200C14D-32GVK (2x16 GB; 3200; CL14; Dual Ranked) @ 2666 MHz stable for some time with 14-14-14-34 timings on 5704 and 5803 - the last time before my C6H bricked it didn't boot with this though, but this could be related to the broken board.
    AndehX PC Specs
    MonitorDELL S2716DG
    CaseCorsair Air 540
    OS Windows 10 64bit
    Mar 2017
    44
    im on 5803 and i've tried every combination of memory slot, and nothing is stable except the default "auto" settings.
    ROG Member Array
    Jul 2016
    18
    Quote Originally Posted by BoMbY View Post
    Thanks all.. i allready have the RAM in A2 and B2...
    G Skilss website says: 16-18-18-38-2N / Should i try your 14-14-14-34 ???
    i will give it a try with bios version 5803 in max few hours. Hope the mobo wont be bricked.
  7. #7
    ROG Member Array
    Jul 2016
    18
    Quote Originally Posted by Menthol View Post
    Majesty_nl,
    Thanks, i allready reading all forms and guides... It would be stupid that only the new Gskill RAM will work with this mobo on higher RAM freqs.
    Hopefully quick bios updates will fix these issues.. The Mobo is really nice but never had so many issues with a board before
  8. #8
    AndehX PC Specs
    MonitorDELL S2716DG
    CaseCorsair Air 540
    OS Windows 10 64bit
    Mar 2017
    44
    I know this is a new platform, but I've also never experienced so many issues with memory before. If bios updates do not resolve these issues, then AMD have really dropped the ball as far as memory support is concerned. I've got 14 days to return my GeIL memory for a full refund, so I intend to look for a memory kit that works properly.
  9. #9
    New ROGer Array
    Mar 2017
    2
    My board showed the exact same behaviour before it broke though the RAM I used (F4-3200C14D-16GTZKW) is listed in the QVL. There was no way to get it to POST above the defaults. Had to clear CMOS each time.
  10. #10
    ROG Member Array
    Jul 2016
    18
    Quote Originally Posted by AndehX View Post
    all platforms do have the same problems. ASUS did probarly sell the most mobos, thats why we see it more often. Maybe it has more to do with AMD then ASUS ...
