Results 1 to 6 of 6
Thread: C6H Fan Control
    ROG Member Array GalaxyDrifter PC Specs
    MotherboardCrosshair VI Hero
    ProcessorRyzen 1700x
    Memory (part number)G.SKILL TridentZ (F4-3200C14D-16GTZKO)
    Graphics Card #1Current - GTX 660TI (Waiting for Vega upgrade)
    MonitorDell 1920 x 1200 24" IPS (U2412M)
    Storage #1Samsung 850 EVO 2TB SATA
    Storage #2Samsung 960 PRO 512GB NVMe
    CPU CoolerCorsair H110i
    CaseCorsair 600Q w/ 5xML140 Pro's (3 on Case + 2 on AIO)
    Power SupplyCorsair RM750x
    OS Windows 10 Home 64-Bit
    Mar 2017
    8
    C6H Fan Control
    I am a retired PC tech, who has been building systems for over 20 years.
    BUT, now it has now been over 7 years since last did a new build. This will be my first water cooling as well as my first use of any real software fan control.
    I am good for most most of the build, but I have a couple of questions about the fans.
    I will be using a total of 5 Corsair 140mm PWM fans, including the two on the H110i radiator.
    My main question is where should I plug the 2x radiator fans? Into the AiO or on the motherboard? Also, why is one preferred over the other?
    Second question is do I want to use Corsairs software, or just use the Asus software?
    There is also a fan controler in the case itself (Corsair 600Q), but I assume that would be the least of the considerations.
    Any advice would be appreciated. Thanks.
    Tech Marketing Manager HQ Array Raja@ASUS's Avatar
    Apr 2011
    161
    7,454
    You can use the chassis fans for fan control if you wish. Corsair's software doesn't play well with the ASUS software, so use one or the other. The ASUS fan control options are a bit more versatile, so I'd go with those. In fact, you can control the headers directly from firmware if you wish - no need to use the software.
    -Raja
    ASUS HQ Service Rep Array
    May 2016
    12
    417
    hi GalaxyDrifte
    ROG CROSSHAIR VI HERO has 4 Fan PWM connectors
    and 2 PUMP connectors for AIO and Water cooling
    my advice is that install PWM fan connector on the 4 Fans
    PWM connectors and H110i pump connect to AIO connector
    about the fan control ,use AI Suite3 or BIOS setting only
    Mar 2017
    8
    But if the radiator fans are plugged into the H110i instead of mb header, will the Asus software and/or bios have direct control over them?
    Mar 2017
    8
    Quote Originally Posted by FuryA@ASUS View Post
    hi GalaxyDrifte
    Ok, thanks.
    If the mb only has 4 fan headers, will I need a splitter for my 5th pwm fan? I was going on the info on the product page which says "5 x 4-Pin PWM Fans".
    Now if I can just get Amazon to send me the board, I will be able to check it myself (pre-ordered on Feb 23)
    Apr 2011
    161
    7,454
    The pump headers can be configured to control fans, and they have the same level of control options.
Tags for this Thread
