Results 1 to 2 of 2
    New ROGer Array
    Jan 2012
    1
    Best usb TV tuner for G74sx?
    Hey there. I recently bought a G74sx and loving it. I would like to buy a usb TV tuner to keep with the machine but ive never actually used one so was wondering is there a certain model that is usually the best? Mostly easiest to use and capable of picking up the best signal. Any input would be greatly appreciated.
    ROG Guru: Orange Belt Array Boosted_R's Avatar
    Aug 2011
    12
    279
    There isn't a special model for G74..... pretty much any USB one will work...... I would check out the Hauppauge WinTV-HVR-950Q, it is suppose to be good.
    GL702VSK / GTX 1070 / M.2 960 EVO
    HTPC MINI-ITX / FRACTAL CORE 500 / GIGABYTE GA-AB350N / GTX 1050 Ti Windforce OC 4G / RYZEN 5 1600 3.9GHz / M.2 960 EVO / G.SKILL Ripjaws V Series 3200MHz
    OLD
    ASUS G74SX-XC1 / INTEL 7260 AC / Samsung 850 PRO / TUNIQ TX-4 / BIOS 203 / 335.23
