Results 1 to 9 of 9
    ROG Enthusiast Array
    Mar 2015
    33
    GTX 1080 mini Zotac with G20?
    Anyone here have purchased a gtx 1080 mini from zotac?
    Is this compatible to our Asus G20? Like will it fit or have enough power for it?
    ROG Guru: Orange Belt Array chilinmichael's Avatar
    Dec 2012
    16
    372
    The best idea is to stick with the reference cards only. The one you are listing here seems to be of the design that it uses case air and circulates it, not good for our PCs.
    Asus G20CB - Core i7 6700, Nvidia GTX980, 16GB Ram, 256GB SK Hynix SSD, 1TB Samsung SSD.
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    318
    7,754
    Michael is correct that you want a blower style cooler, not open air.
    As for power, if you have the dual power supply setup 180w+230w adapters then you can run a 1080 (newest G20 has 1080) just not the 1080 Ti. Just go with a blower style 1080 and you'll be good.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    ROG Guru: Orange Belt Array Welsh Whoopee's Avatar
    Jan 2016
    18
    261
    Quote Originally Posted by Gengaku View Post
    that card won't fit into the asus rog g20 anyway dude, yeah founders edition is the best way but the turbo version is like the founders but cheaper
    [B]YOUTUBE CHANNEL @ https://bit.ly/2E1zKTE
    ASUS ROG G20 PLAYLIST @ https://bit.ly/32uD4Py
    ROG Guru: White Belt Array spartan_hoplite PC Specs
    Laptop (Model)ROG G21CX Huracan
    MotherboardZ390 ROG G21CX
    ProcessorIntel Core i9 9900k
    Memory (part number)32gb DDR4
    Graphics Card #1ASUS RTX 2080 Turbo
    MonitorROG PG27vQ
    Storage #1Samsung NvMe 960 500gb + 4 Tb Samsung SSD
    Storage #2Seagate 8 tb Hard Disk Drive
    CaseROG G21CX
    Keyboard ASUS ROG Claymore
    Mouse ASUS ROG Pugio
    OS Windows 10 Pro
    Nov 2013
    21
    77
    The card won`t fit. I bought one. the actual card is much larger than shown on zotac website.
    Expectation:
    Reality:
    Mar 2015
    33
    Quote Originally Posted by spartan_hoplite View Post
    Expectation:
    Reality:
    Tnx for taking one for the team this helps ALOT. Was deciding on getting this one since it is a bit faster than reference model.
    I guess I need better options.
    Now I'm wondering if the strix version will fit if we make a few modification with the case. Any thoughts?
    Thanks to everyone who replied for more info about the power and type of gpu compatible with the unit.
    I'm planning to get the 230w extra adapter since I already have the 180w one.Will be getting this from local ASUS service provider.
    And yes the blower type gpu is most benificial for the G20
    I'm just wondering why they sell this G20 with a gtx 745 which is not a blower type designed gpu.
    So was thinking a mini gtx 1080 would work as well. Thanks again!
  7. #7
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    318
    7,754
    The 745 is a *very* low wattage part so it generates much less heat and a blower is less critical. I couldn't even find TDP with a cursory search but it's going to be less than the 55w of the 750.
  8. #8
    MonitorROG PG27vQ
    CaseROG G21CX
    OS Windows 10 Pro
    Nov 2013
    21
    77
    The strix version won`t fit, the cooler is much too big. The only model that fit is the founder edition & Asus Turbo version.
  9. #9
    ROG Guru: Yellow Belt Array Ravenholme PC Specs
    Ravenholme PC Specs
    Laptop (Model)Asus G20AJ-US009S
    MotherboardAsus H97
    ProcessorIntel Core i7 4790
    Memory (part number)16GB - Kingston DDR3 1600MHz CL11 1.35v SODIMM - KVR16LS11/8
    Graphics Card #1Nvidia GeForce GTX 1080 - Founders Edition (ASUS)
    MonitorBenQ BL3201PH (4K/UHD IPS LED)
    Storage #1Samsung 850 Evo 500GB SSD
    Storage #2Seagate SSHD 1TB
    CaseAsus G20AJ
    Power SupplyAsus 180W PSU AC Adapter + Dell Y90RR 330W PSU AC Adapter
    Mouse Razer Ouroboros
    Headset Turtlebeach
    Headset/Speakers (The BenQ)
    OS Windows 10
    Accessory #1 ASUS (SBC-06D2X-U) Slim External 6x Blu-ray Combo Drive
    Accessory #2 Asus GPU Tweak II - OC: 2050 Mhz, 90°C max, 120% Power, vsync off
    Accessory #3 http://rog.asus.com/realbench/show_comment.php?id=8796
    Ravenholme's Avatar
    Mar 2015
    169
    Honestly Stick with Reference / Founders Edition cards. those have proper spec measurements that will absolutely fit. anything outside that spec WILL NOT fit. I use a Founders Edition GTX 1080 and it fits and runs fine since release.
