Results 1 to 3 of 3
    New ROGer Array
    Mar 2017
    3
    Post Upgrability of G20CB?
    Can the GTX 1080 fitted in the G20CB be upgraded? Briefly, can you please let me know what would entail for upgrading? And, the complexity of the procedure?
    Thank you!
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    300
    7,446
    I pretty much answered this question 2 days ago in your other thread:
    https://rog.asus.com/forum/showthrea...l=1#post636431
    The 1080 is the most powerful card available that will work in a G20. Not enough power for a Ti and you can't add the needed power without extensive warranty-voiding modification. You would be better off buying a different PC pre-built with a 1080 Ti.
    Perhaps next generation you could upgrade to a "GTX 1180", as long as the power requirements are similar to the 1080.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    ROG Guru: Yellow Belt Array Welsh Whoopee's Avatar
    Jan 2016
    17
    230
    Quote Originally Posted by abhisheksha View Post
    Thank you!
    yeah the G20CB has loads of upgrades, from cpu to memory and ssd and graphics card, its not hard to upgrade and I have videos on how to do so, you will void your warranty if you open your machine so check the age of pc and if you want to take that risk. also the gtx 1080 will fit, best card is the founders edition
    Whoopee
    YOUTUBE CHANNEL @ http://bit.ly/2LNo1dI
    ASUS ROG G20 PLAYLIST @ http://bit.ly/2R9njXC
