Hello people,
I recently build my new pc (
https://pcpartpicker.com/user/TeddyBeer/saved/j2xp99).
And i realized yesterday that my monitor was running at 4K, but 24hz instead of the normal 60.
I tried to go into the Nvidia control panel to change it, and among the propositions, I can't get anything but 23 or 24hz with any resolution above 1920*1080.
I then tried to create a personalised resolution (where you can set anything you want), but whenever I test the setting i put in, screen goes black says "HDMI no signal", and doesn't save the changes. I'm using the cable that came with the monitor, and it's plugged in the graphics card.
I have the drivers installed, and at this point, i'm out of ideas.
