Results 1 to 6 of 6
    ROG Guru: White Belt Array MMikhail PC Specs
    MMikhail PC Specs
    Laptop (Model)ASUS N76V
    MotherboardASUS Z170-A
    Processor6700K
    Memory (part number)Crucial Ballistix DDR4 32GB
    Graphics Card #1STRIX GTX 1070 OC
    MonitorAMVA3+ LCD 24 FHD
    Storage #1Crucial SSD
    Storage #2WD HDDs, stack
    CPU CoolerEVO 212
    CaseFractal Define R5
    Power SupplyHX750i
    Keyboard Razer Deathstalker
    Mouse Razer Deathadder
    Mouse Pad Func Ultra
    Headset/Speakers Creative T30
    OS Win10 x64
    Network RouterZyxel Ultra
    Jan 2017
    13
    88
    RealBeanch 'Instability detected...' issues, why and how to solve?
    I have been battling with the dreaded RealBeanch 'Instability detected...' issue for a very long time and now I believe I have found the reason why it is happening, or more precisely I know how to trigger it or how to prevent it.
    Setup: Asus Z170-A (3301) , 6700K (4.2), 4x8GB(2666 at 2400), STRIX 1070, Win10 (all updates to current date)
    If I run RB stress test and keep the system busy from going to screensaver mode (Have it set at 10 mins) the test can run indefinitely without problems.
    In fact it's enough to move the mouse a little every 8 mins and keep the system busy with RB.
    But if you leave RB running unattended and screensaver kicks in, we are waiting for trouble.
    The screen saver is a default slideshow one that come with windows, nothing special, so how does it effect the system is a mystery.
    But possibly something is triggered in windows that does harm.
    In other words, you are likely to get the instability detected warning and RB stress test stopped within minutes after the SS.
    This can be easily spotted by quickly updating images in the slideshow, during RB stress test they update slowly.
    So here comes the question for the brainy people here.
    What can we do? Any particular setting in UEFI can help ? Or is it a MS bug?
    ROG Guru: Brown Belt Array MeanMachine PC Specs
    Laptop (Model)I enjoy my wife
    MotherboardCVI HERO + CVII Hero Wifi
    ProcessorRyzen 7 1800X + 2700X
    Memory (part number)CMD16GX4M2B3000C15 + F4-3200C14D-16GTZR
    Graphics Card #1EVGA GTX980 SC for CVFZ
    Graphics Card #2EVGA GTX 1080 hybrid
    Graphics Card #3GTX 770 for phys x
    Sound CardMB
    MonitorHP w2408h
    Storage #1Samsung 970 EVO 500GB M.2
    Storage #2Samsung 840EVO 500GB and 960 M.2 pro
    CPU CoolerCorsair H105, H110 and H115i
    CaseCorsair 750D and 780T
    Power SupplyCorsair AX-1200i and Antec 850 pro platinum
    Keyboard Logitech K800
    Mouse Razer Mamba
    Headset Corsair Vengeance 2100
    OS W7 Ultimate 64bit and W10 pro 64bit
    Network RouterNetcom Wireless NF18ACV
    MeanMachine's Avatar
    Apr 2014
    126
    1,675
    Why don't you just have your Screen saver disabled or set timer to come on after test has finished (Wait time is your choice) when running Realbench. You don't get the best results with Realbench with apps open in test mode nor benchmark.
    In W10, right click on desktop and choose Personalize. When menu appears search for Screen saver and it will search then bring up settings.
    We owe our existence to the scum of the earth, Cyanobacteria
    My System Specs:
    MB:ASUS ROG Crosshair VII Hero/WiFi GPU:EVGA GTX 1080 sc PSU:Corsair AX-1200i
    CPU:
    AMD R7 2700X Cooler: Corsair Hydro H115i Case: Corsair Carbide 780t
    Memory:G.Skill TridentZ F4-3200C14D-16GTZR SSD:Samsung 500GB 960 EVO M.2
    MMikhail PC Specs
    Processor6700K
    CPU CoolerEVO 212
    Power SupplyHX750i
    OS Win10 x64
    Jan 2017
    13
    88
    I am not referring to benchmarks but to stress test loop and how it works.
    If there is no real problem on the system, why does is fail ?
    Does it check for changes in system performance?
    And really, it would have always helped if the error was more verbal.
    eg. failed crc check in test xxx, or result of some operation gave unexpected result.
    Currently it's a guess yourself.
    Anybody tried to run RB stress test with slideshow screensaver active and a few large jpeg files?
    MMikhail PC Specs
    Processor6700K
    CPU CoolerEVO 212
    Power SupplyHX750i
    OS Win10 x64
    Jan 2017
    13
    88
    SOLVED!
    RealBench 2.44 causes false positive instability reports when Windows ScreenSaver engine is enabled.
    Solution:
    Use RealBench 2.53b, has build in temperature monitoring and works! Peace of mind and finally relax ;-)
    (Took numerous hours of testing, actually days, and overall over 4 moth of stress and headaches)
    ROG Member Array wmakaiwi PC Specs
    wmakaiwi PC Specs
    Laptop (Model)Home built PC - Dime Bolt
    MotherboardAsus ROG Maximus VIII Hero
    Processori7 6700k 4.6 GHz
    Memory (part number)Corsair Vengeance LPX 3200
    Graphics Card #1EVGA GTX 970 FTW 2.0+
    Graphics Card #2EVGA GTX 970 FTW 2.0+
    Sound CardOnboard - SupremeFX
    Storage #1480 GB SSD
    Storage #2960 GB SSD
    CPU CoolerCorsair H100i v2
    CaseCorsair Carbide 300R Windowed
    Power SupplyEVGA SuperNova 1300W G2
    Keyboard Razer DeathStalker
    Mouse steelseries RAW sensei
    OS Windows 10 Pro X64
    Network RouterAsus RT-AC3100
    Jun 2014
    9
    Quote Originally Posted by MMikhail View Post
    SOLVED!
    Solution:
    +1
    I've been dealing with this since Sunday. I'd go crazy and scrap the PC after 4 months. But as you stated....Peace of mind and time to relax..maybe start enjoying games again.
    untouched Array Praz's Avatar
    Apr 2011
    137
    4,038
    Hello
    There is already one thread regarding this non-issue. Closing this one.
Tags for this Thread
