Results 1 to 2 of 2
    ROG Member Array lexo1000's Avatar
    Mar 2017
    12
    Bad i5 7600K overcling capability ! Help :(
    Hello, My brand new i5 7600K up max to 4.6GHz (with AVX offset of 2 otherwise OCCT crashing). So with AVX activated, my CPU goes to 4.4 max, 200Mhz better than stock ... My cooler is a BeQuiet AIO Silent Loop 240mm & my motherboard an Asus Strix Z270i Gaming. Even if I put more voltage (1.4V), impossible to have a stable machine with more than 4.6Ghz. I see all over the web everybody that push that CPU to 5Ghz easily... Is my CPU is the best potatoes Kaby Lake ?
