Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
    ROG Member Array
    Mar 2017
    16
    Bios problem 0902 and does Crosshair VI Hero supports Vengeance Led DDR4 3200?
    Hello everyone,
    Is there any problem with Vengeance Led 3200 2x8Gb. I couldn't find "CMU16GX4M2C32200C16R" on memory support page and worker of computer store said that mainboard is supports 3200mhz memory and gave me that memory. But when i checked box of mainboard i can't see that mainboard supports 3200 mhz. Only says "max 4 x dim 64 gb 2666mhz/" and lower. It's same about handbook of mainboard. Should i change my ram?
    And another problem about bios. I've checked bios 0902 few days ago and it was in beta and yesterday i saw that 0902 released, so i wanted to try it. But it made me regret and really don't know why did they remove 0702 version from website. It's really weird and when i clear cmos, it's still show 0902 version. System really freezes randomly, can't play any games, temp shows 65-70 at iddle, cpu works 1ghz and voltage between 0,4 and 0,8.How can these things happen with republic of gamers mainboard. Other users already got high K mmr and etc. We still waiting for boot our computer. And i'm really bored from solitare.
    (And my few angry things about this mainboard)
    Dear Asus, this is not early access game or dayZ. You design this mainboard for gamers and overlockers but that was really logical to place bios cell beside graphic card slot. So when i wanna remove cell, firstly i have to remove my graphic card... And i play piano, i have thin fingers but they are really big and useless to use jumper, because you place that thing most weird place on the board. Thank you that you sell bad mood for a lot of money.
    ROG Enthusiast Array AndehX PC Specs
    AndehX PC Specs
    Laptop (Model)Dell Latitude E6230
    MotherboardASUS Crosshair VI Hero
    ProcessorAMD Ryzen 7 1700
    Memory (part number)CMK16GX4M2B3000C15
    Graphics Card #1Gigabyte GeForce GTX 1080 Xtreme Premier Pack Edition 8192MB
    MonitorDELL S2716DG
    Storage #1Intel 600P 256GB M.2 SSD
    Storage #2Toshiba DT01ACA300 3TB HDD
    CPU CoolerCorsair H100
    CaseCorsair Air 540
    Power SupplyEnermax Revolution85+ 850W
    Keyboard Corsair K75 RGB MX Brown
    Mouse Finalmouse 2015 Summer edition
    Headset Audio Technica ATH-AD500X / Astro Mixamp 2016
    Mouse Pad Mionix Sargas 400
    OS Windows 10 64bit
    Mar 2017
    44
    you do realize that there is a clear CMOS button on the back of the board next to the USB ports right? If you can't even work that out, maybe you shouldn't be tinkering with overclocking stuff....
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    498
    13,531
    OP clearly states he has cleared CMOS...if you can't read...
    OP...BIOS 0902 is the only recommended BIOS for the board at this time. Previous BIOS have been removed because in some circumstances boards were dying.
    RAM for this platform is a work in progress. Best to buy QVL. Or wait for incoming qualified kits from the likes of G.Skill...
    For now...and while BIOS work is being done maybe run RAM at stock....
    Things will mature slowly.
    ROG Member Array
    Mar 2017
    16
    Quote Originally Posted by AndehX View Post
    Hello! Typical writer of forums or fanboy. Whatever...
    AndehX PC Specs
    MonitorDELL S2716DG
    CaseCorsair Air 540
    OS Windows 10 64bit
    Mar 2017
    44
    Quote Originally Posted by MeQira View Post
    Excuse me? This is a forum for help and advice. It's not the place for childish insults.
    If you say you've reset the bios using the button, then why are you trying to remove the battery? The button works just fine. There is no need to remove the battery. Resetting the bios or removing the battery will not make it revert back to a previous bios version. Once 0902 is flashed, it is there until you flash a different version.
    ROG Member Array
    Mar 2017
    16
    Yes, that's the point. I'm glad that you learned it.
    And i'm confused about bios. When i bought it, bios version was 0702. I've removed cell because i tried many times to back 0702 with using "clear cmos" which button exist rear panel and all fan settings are gone but version was still 0902. So i removed cell and after that bios version was 0503 or 0508.
    In my country we are not that lucky to upgrade systems or buy new computer every year. My old mainboard has dual bios and i don't know a lot of things about C6H. I didn't search a lot things, because I'm a tired hardcore fsx user whom just lost 1.5 TB addons, tweaks of that game.
  7. #7
    AndehX PC Specs
    MonitorDELL S2716DG
    CaseCorsair Air 540
    OS Windows 10 64bit
    Mar 2017
    44
    Sorry but I wont be offering any more help or advice with that attitude.
  8. #8
    Apr 2012
    498
    13,531
    This is not help and advice
  9. #9
    ROG Guru: Green Belt Array haihane PC Specs
    haihane PC Specs
    MotherboardCrosshair V Formula Z
    ProcessorAMD FX 8350
    Memory (part number)Gskill F3-2400C10-8GTX
    Graphics Card #1ASUS HD 6950
    Storage #1WD Velociraptor 1TB
    Storage #2Corsair Neutron GTX 120GB SSD
    CPU CoolerCooler Master Seidon 120XL
    CaseCooler Master Silencio 650
    Power SupplyCorsair HX850
    Keyboard Corsair K70 RGB
    Mouse Logitech G500
    OS Windows 7 X64
    Network RouterLinksys E2500
    haihane's Avatar
    Jul 2013
    106
    616
    agreed with Arne.
    the way that's phrased is as if you're standing on high pedestal of Overclockers looking down on mere noobs, and they shouldn't even try for making a minor mistake.
    i do too read you said in other thread you had like what, 15 years of experience?
    while i may not have that much experience (well, i destroyed quite a bit of PCs starting from intel 486, did overclocking via FSB, taking care of PCI/AGP ratio, and who remembers drawing pencil lines on L1 bridge on K7 athlons?)
    and i wouldn't use that kind of condescending tone first unless provoked.
    i'm not even surprised that OP did a knee-jerk counter retort.
    no siggy, saw stuff that made me sad.
  10. #10
    AndehX PC Specs
    MonitorDELL S2716DG
    CaseCorsair Air 540
    OS Windows 10 64bit
    Mar 2017
    44
    Quote Originally Posted by haihane View Post
    agreed with Arne.
    It wasn't supposed to sound condescending or as if I was looking down on anyone. It was genuine advice that if you do not even know how to properly clear the CMOS, then you shouldn't really be messing with overclocking. That is genuine advice to avoid having to RMA a motherboard.
