Results 1 to 7 of 7
    New ROGer Array
    Nov 2015
    2
    Help and Worries upgrading G20 to a 1080 and i7-6700k
    So I know this has been said 100 times in other threads. But still I wanted complete confirmation before I went out and spent a lot of money. I want to upgrade my G20 (750, i5 4460, 8gb Ram) to a 1080 and a i7-6700k. I know I have to get the secondary 180w pw supply but even with the two supplies in should the wattage be enough to handle both the gpu and the cpu with no problems? Also will they fit in the machine?.
    Links:
    (180w power supply)
    https://www.amazon.com/gp/product/B0...ter&pldnSite=1
    (GTX 1080)
    https://www.amazon.com/EVGA-GeForce-.../dp/B01FWI6F08
    (i7 6700k)
    https://www.amazon.com/Intel-Unlocke...words=i7+6700k
    Thanks for the help!
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse ROG Chakram Core
    Mouse Pad Steelseries QCK Prism XL
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,437
    Hi Aubinox123
    Welcome to the ROG forum.
    the i5-4460 is socket 1150, the i7 6700k is socket 1151 so nope it won't work.
    As for the 1080 it peaks at 180w so you're right on the edge, I personally don't like to live on the edge with power. You might want to get the 230w psu to give you some headroom.
    Or just build you a nice desktop with a new ROG z270 motherboard and 7700k.
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    336
    8,001
    Quote Originally Posted by Nate152 View Post
    Hi Aubinox123
    The 180w PSU is running the entire PC so he definitely needs the secondary PSU with any upgrade.
    @Aubinox123 - The fastest CPU for that generation machine is the 4790. If you want anything newer then Nate is correct that you'd have to build a new machine.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    New ROGer Array
    Nov 2015
    2
    Thank you! I already have the 230w I forgot to mention that in the post so I'm getting the 180w to get the full 410w, thank you for the i7 warning ill be sure to get a 4790k instead.
    ROG Guru: Orange Belt Array chilinmichael's Avatar
    Dec 2012
    16
    372
    Get a regular (non-k) model, K marker indicates unlocked, you don't need that (and can't utilize it either) unless for some reason you find that cheaper, which should be the opposite (regular should be cheaper)
    Asus G20CB - Core i7 6700, Nvidia GTX980, 16GB Ram, 256GB SK Hynix SSD, 1TB Samsung SSD.
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    336
    8,001
    I originally thought they would be the same as well but the K version actually has a higher clock speed.
    https://ark.intel.com/products/80806...up-to-4_00-GHz
    https://ark.intel.com/products/80807...up-to-4_40-GHz
  7. #7
    ROG Guru: Orange Belt Array Welsh Whoopee's Avatar
    Jan 2016
    18
    261
    yeah as said above, the max is the i7 4790k LGA1150 & the 180watt power brick, if you want the gtx 1080ti then your need a 230watt power brick+
    worth upgrading to 16gb of ddr3 memory while your in the cpu area, as the cpu cooler has to be taken off to access the cpu
    Whoopee
    [B]YOUTUBE CHANNEL @ https://bit.ly/2E1zKTE
    ASUS ROG G20 PLAYLIST @ https://bit.ly/32uD4Py
