03-16-2017 03:08 AM - last edited on 03-05-2024 10:38 PM by ROGBot
03-16-2017 07:01 AM
03-16-2017 10:42 AM
MNMadman wrote:
Immature Ryzen/AM4 platform is not ready for full RAM speeds. You will need to wait for future BIOS updates to enable full speed. It will likely be many months for full compatibility and stability.
03-16-2017 11:17 AM
Upgrade01 wrote:
That is what I was thinking but it appears that some people are able to achieve these speeds which they probably just got lucky. Also, I have been hearing about AM4 cpu coolers being mounted too tight could causing some weird issues. Is this a true?
03-25-2017 08:37 PM
03-26-2017 11:19 PM
03-27-2017 03:32 AM
03-28-2017 08:42 AM
Decoman wrote:
@jbasemoine
What is your SOC voltage? (iirc, I read that it is supposed to be as low as possible, and not higher than 1.20V with current bios', because it makes things hot)
And how many sticks are you using for that ram overlock of yours?
03-28-2017 02:08 PM
