X370 Pro prime Aura Problems
Awsalli
When I try to open the software, the software fails. I uninstalled the software and installed it again. Problem not solved.
WARNING: Following frames may be wrong.
aura+0x5e33e
aura+0x6adf7
aura+0x37449
qt5core!QMetaObject::activate+0x4cf
https://drdump.com/Problem.aspx?ProblemID=267869
67 REPLIES 67
tardisguy
Same issue on the crosshair board.
Little mad, ya'kno.
Ive even pulled the board and its battery and let it sit 30 minutes.
Seeing the same issue on my Crosshair Vi.
Same here.
Do your mainboard LEDs/AMD Wraith actually light up? Mine stay off all the time.
Not that I need that but the lack of irritates me 😉
It happened after graphics change from Nvidia GT640 to Radeon HD6770. I reinstalled all software and even returned to 0502 bios. Nada
aura+0xed0e
aura+0x6edec
aura+0x2505c
aura+0x72389
Having the exact same error on my ASUS CROSSHAIR VI HERO AMD X370 DDR4 S-ATA 600 ATX Motherboard in the AURA software, the following lights were working fine https://www.youtube.com/watch?v=wDzqpVv7YsU
The error was:
https://drdump.com/UploadedReport.aspx?DumpID=14151413&SecondVisit=1
I have found completely wiping the software from my system (deleting from program files after installing etc...) then reinstalling makes the software work again.
It did not make the lights come on.
Additionally have tried enabling and re-enabling the lights on the motherboard bios software after leaving the power unplugged for several hours.
It does not seem as though the LED's have blown which I highly doubt anyway.
All software relating to the motherboard and BIOS is completely up to date.
I can only deduce that the problem lies within the ASUS software? I have tried all sortsof configurations in the software and such.
As I deduced its not the capacitors holding the light off data, I presume its either the BIOS battery therein somehow or the software overall?
Be good to figure out a fix for this.
I have the same problem and I did not find a solution yet
Mine too! I have replied everywhere all over the forum, hopefully they may take notice!
I think the Aura chip has flash memory built in to remember its settings. The G.Skill RGB RAM seems to use the same controller chip and it can store settings even when the stick is removed from the case, so highly doubt it's battery related. The default button in the Aura app seems to work every time I get mine into an unresponsive state.
Just tried that and nothing happened 😞
See my other thread I created, it seems quite a few people are having this issue with my board.
https://rog.asus.com/forum/showthread.php?92092-Possible-Aura-or-motherboard-issue
