PCI-E Power Cable for GTX 1060 Upgrade
Mortified_Mak
I recently purchased an EVGA GTX 1060 6gb for a G20AJ, I was able to upgrade my cpu, but I'm extremely noobie still.
The 1060 is a single 6 pin card, so should I purchase a 6 pin to 6 pin, or a 6 pin to 8 pin? Would this be viable?
https://www.amazon.com/Silverstone-Sleeved-PCI-E-8-Pin-PP06B-PCIE55/dp/B00A45JA52/ref=sr_1_1?s=pc&ie...
The 1060 says to only use PCI-E.
Specs:
CPU: i7-4770s
GPU: GTX 745
RAM: 8gb Crucial
Asus11
if the 1060 is a 6pin card, using a 6 pin would work perfectly there is no need to use a 6 to 8 pin, that is for 8 pin cards
Welsh_Whoopee
Level 11
the 6pin to 6pin is fine to use and don't worry about not using the other power port
I too am installing a gtx 1060 turbo in my g20aj-nr036s, when going from a gtx 970 that uses both 6 and 8 pin connectors to the 1060 with only the 6 pin- do i have to change any of the pins on the board in order for it to work or is it "just plug and play"?
Kind regards, Joakim
