Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    ROG Member Array
    Oct 2013
    12
    Bios Flashback does not work M8G.CAP
    Trying to roll back bios to 1902 from 3007 as the ram no longer overclocks beyond xmp 3200c14 when it use to hit 3866 16-16-16 1.425v stable
    Im guessing this is due to me having a 6700k and the bios is better suited to 7700k
    MAXIMUS-VIII-GENE-ASUS-1902.CAP renamed M8G.CAP on a freshly formatted usb in the port shown in the manual
    Flashback button flashes 3 times then stays illuminated and nothing happens
    Tried two usb (sandisk\transcend) and powering off the system completely before trying
    Thanks
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,255
    Did you format the USB pendrive to FAT32? Also try using other pendrives that don't have a hidden partition. The Sandisk ones normally have one. Can't say for the Transcend.
    ASUS HQ Service Rep Array
    May 2016
    12
    417
    As Chin said, You must check the USB format to FAT32
    and try to flashing again
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH EXTREME
    ProcessorTHREADRIPPER 1920X
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    481
    13,400
    Maybe use diskpart to make sure you are placing file on root of pendrive
    https://rog.asus.com/forum/showthrea...l=1#post398383
    ROG Guru: White Belt Array Buellersdayoff PC Specs
    MotherboardMaximus viii Hero
    ProcessorI7 7700k delidded 4.9ghz @ 1.4v
    Memory (part number)Corsair led 4x8gb 3200
    Graphics Card #1GTX 1080ti MSI Gaming X
    Sound CardOnboard + Hyperx usb
    MonitorAcer X34 Predator
    Storage #1Samsung 950pro nvme
    Storage #2Samsung 840 ssd + 2tb hdd
    CPU CoolerCryorig R1 Universal
    CaseThermaltake View 31 TG mesh front panel mod
    Power SupplyCorsair rm850x
    Keyboard G910
    Mouse G502
    Headset Hyper x cloud II
    Mouse Pad H440
    Headset/Speakers Edifier R1280t
    OS Win 10
    Network RouterNetgear x8 R8500
    Aug 2016
    117
    My manual shows the wrong USB port
    ROG Member Array
    Oct 2013
    12
    So the green arrow is correct?
    Confirmed both flash drives are formatted fat32
    Neither USB port responds any differently at this stage
    Will borrow some corsair USB sticks and see if they work
    I know there different to the Sandisk as the Corsair don't detect on boot for windows installation
    Thanks for all the suggestions
  7. #7
    Apr 2012
    481
    13,400
    No....the green arrow is just an ordinary usb port...it clearly labels rog connect port...bios flashback port next to it right?
    EDIT:....OK don't mind me...that's what happens when browsing on a phone
  8. #8
    Oct 2012
    339
    15,255
    Quote Originally Posted by Dasa2 View Post
    If possible, try to use small capacity drives like 4GB or 8GB. It doesn't even have to be any fancy pendrives. I've seen users buying $5 pendrives and they work fine.
  9. #9
    Keyboard G910
    Mouse G502
    Mouse Pad H440
    OS Win 10
    Aug 2016
    117
    I'll double check and confirm later, the manual confused me,
    In this picture it is indicating the port next to the LAN, as my previous pic of the manual points to below the PS2.
    Pretty sure it was the one with the green arrow, try different ports till it works.
    Someone stuffed up with manual anyways.
    ^page from an overclock guide.
  10. #10
    ROG Member Array
    Oct 2013
    12
    Never did get the bios flashback to work even after trying 4 more usb sticks in both ports but thankfully the latest bios 3401 overclocks ok again so I didn't have to use it to roll back
