Results 1 to 10 of 10
    ROG Member Array Wowerus PC Specs
    Wowerus PC Specs
    MotherboardHero VIII Hero
    ProcessorI7-6700K Skylake
    Memory (part number)Corsair Vengeance LPX DDR4 2133MHz
    Graphics Card #1GTX 1080 Strix Asus
    MonitorASUS ROG Swift PG278Q x2
    Storage #1Samsung 850 EVO 500GB SSD
    Storage #2Seagate® Desktop SSHD 4TB
    CPU CoolerNoctua NH-U14S
    CaseNZXT Phantom 820 Big Tower
    Power SupplyEVGA Supernova G2 850W
    Keyboard Steelseries Apex M800
    Mouse Steelseries Rival 700
    Headset Steelseries Sibera 800
    Mouse Pad Steelseries Dex
    OS Windows 10 Home
    Apr 2016
    15
    Hero VIII Bios Update problem
    I am trying to update my BIOS as I am having trouble with some devices and was told to update. Once I had updated to the most recent at the time (2202) I only got a black screen. I downloaded an older version and the PC started. I am looking into trying to update once more and was wondering before I do what can cause the black screen problem. I am updating using the USB BIOS flashback utility. I am following the manual.
    Nate152 PC Specs
    Memory (part number)16GB G.Skill Trident Z 4000MHz 16-16-16-39-2T
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Power SupplyPC Power & Cooling Turbo Cool 1200w
    Keyboard Razer Anansi
    Mouse Logitech G500
    Headset Sennheiser HD6XX
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,344
    It could be because it's not flashing properly.
    1) Format an empty usb flash drive to FAT.32
    2) Download the bios file from the asus support center
    3) Extract the bios file to the usb flash drive
    4) Rename the bios file to M8H.CAP
    5) Insert the flashdrive into the ROG Connect port
    6) Press and hold the bios flashback button until it starts to flash then release. The flashing should get faster and faster then stop, the update process should take around 90 seconds to complete
    7) When flashing stops, Start your pc
    Wowerus PC Specs
    OS Windows 10 Home
    Apr 2016
    15
    Will try it out! Thanks. I am actually using the Maximum as your guide shows. Will write back after I have done it.
    Wowerus PC Specs
    OS Windows 10 Home
    Apr 2016
    15
    Quote Originally Posted by Nate152 View Post
    4) What motherboard are you using? As an exapmle the Maximus VIII Formula would get renamed to M8F.CAP
    I get the same thing. My screens do not start after bios update.. I did however use M8H instead as the manual say ot should be that.
    Nate152 PC Specs
    MonitorHP ZR30w
    Mouse Logitech G500
    Nate152's Avatar
    Feb 2013
    308
    16,344
    Yes rename the file to M8H.CAP sorry about that.
    Try updating to bios version 3101.
    Wowerus PC Specs
    OS Windows 10 Home
    Apr 2016
    15
    I am a bit afraid of updating as it seems to be harder every time for me to get the computer to start afterwards. Aka downgrade it back.
    I will however try later because right now some friends and I are going to play.
    But should I continue with the USB BIOS flashback way or should I try booting into UEFI updating from there?
    I read that I might need to press the CMOS reset and when the update is complete let the computer boot for a couple minutes for it to start completely.
  7. #7
    Nate152 PC Specs
    MonitorHP ZR30w
    Mouse Logitech G500
    Nate152's Avatar
    Feb 2013
    308
    16,344
    Yes clear the cmos before updating the bios and use the bios flashback feature.
  8. #8
    Wowerus PC Specs
    OS Windows 10 Home
    Apr 2016
    15
    Just to clarify fully.
    1. Shutdown computer.
    2. Open Case and press Clear CMOS button.
    3. Insert USB including M8H.cap file in root dir
    4. Press Flash button and let it flash blue until it turn of
    5. Start computer and gaze on updated bios.
  9. #9
    Nate152 PC Specs
    MonitorHP ZR30w
    Mouse Logitech G500
    Nate152's Avatar
    Feb 2013
    308
    16,344
    That's correct.
  10. #10
    Wowerus PC Specs
    OS Windows 10 Home
    Apr 2016
    15
    Hello. I finally did this and my computer is dead, well it feels like that. I have tried reverting it back to the old Bios but even that does not work now.
    When booting the computer I get d0 qcode now. If I press the MemOK I get to Bios. I have searched on the web and most talk about RMA.
    Update: Tinkered and did everything more times. Got it to boot when using the 2002 Bios Version.
    So I did manage to save the computer but can not update bios anyway.
Tags for this Thread
