03-25-2017 09:54 AM - last edited on 03-05-2024 10:37 PM by ROGBot
03-25-2017 10:00 AM
03-25-2017 10:22 AM
03-25-2017 10:27 AM
03-25-2017 10:44 AM
Nate152 wrote:
It will work, the Trident Z is notorious for working well with the Maximus boards and the Code supports up to 4133MHz ram.
I have no doubt the Code is capable of running ram at that speed but it's up to the cpu's IMC if it can handle it. You may get lucky and it will work with XMP or you may have to manually set and tune.
So yes with the Code and likely with the cpu too, preferably the i7-7700k as the i7's have a stronger IMC.
03-25-2017 10:58 AM
03-25-2017 06:20 PM
03-25-2017 10:29 AM
03-25-2017 10:44 AM
03-26-2017 12:50 PM
