Results 1 to 6 of 6
03-25-2017 05:52 PM #1New ROGer Array
- Join Date
- Mar 2017
- Reputation
- 10
- Posts
- 3
Bluetooth/Wifi on Strix Z270E not working at all
Set up my Strix Z270E this morning, wifi & bluetooth worked fine. Had some issues trying to install my MX Master via bluetooth, but there were some updates so I did those, including a BIOS update to 0801.
Restarted - no bluetooth. It's not even showing up in the list. Wifi working fine. Try a ton of stufff, nothing works.
Couple hours later, trying to set some overclock settings. Didn't work though, so I gave up for now and reset BIOS to defaults, then change a few settings back the way I like them. Boot into Windows - now the wifi isn't working either. The hell?
Any ideas on how to fix this?
03-25-2017 06:12 PM #2Moderator Array Nate152 PC Specs
Nate152 PC Specs Motherboard ROG Strix Z690-F Gaming WiFi Processor i7-12700KF Memory (part number) Kingston Fury Beast 16GB (2x8GB) 6000MT/s (KF560C40BBK2-16) Graphics Card #1 ROG Strix 3090 Ti LC OC Sound Card ROG SupremeFX Monitor HP ZR30w Storage #1 Seagate Firecuda 530 1TB CPU Cooler EK Quantum Velocity2 Case Thermaltake Tower 900 Power Supply EVGA Supernova 1600 T2 Keyboard ROG Falchion NX / Strix Flare II/Azoth Mouse ROG Chakram X/Chakram Core/Spatha X/Harpe Ace Headset ROG Delta S Animate Mouse Pad Steelseries Prism XL / ROG Scabbard II/Hone Ace OS Windows 11 Home Accessory #1 2x Swiftech Maelstrom X300 D5 V2 Accessory #2 2x Hardware Labs SR2 560 MP radiators Accessory #3 Lamptron FC-5 V3 fan controller
- Join Date
- Feb 2013
- Reputation
- 404
- Posts
- 17,790
Hi eclenic
Welcome to the ROG forum.
Those are two features I don't use but as for your wifi disappearing after overclocking, it sounds like your overclock could be unstable.
As for bluetooth check to see it's enabled in the bios, Advanced tab > Onboard Device Configuration.
Reset to defaults and see if your wifi comes back.
Check device manager for any yellow triangles.
03-25-2017 06:24 PM #3New ROGer Array
- Join Date
- Mar 2017
- Reputation
- 10
- Posts
- 3
Hi, thanks for replying.
Yes the overclock wasn't stable, hence resetting BIOS to default settings before booting into Win 10. *I haven't tried overclocking again yet.
I've updated the BIOS to 0906 now, issue still persists and I'm now reinstalling Win 10 for the second time today.
Device manager has one yellow triangle, 'PCI something' (not at desk just now) which google says is to do with the Intel Management engine software.
Also of note, what used to say 'Qualcomm Atheros Wireless Adapter' under networks adapters has disappeared and now there are a bunch of different 'WAN miniport' entries instead.Last edited by eclenic; 03-25-2017 at 07:21 PM.
03-25-2017 07:23 PM #4New ROGer Array
- Join Date
- Mar 2017
- Reputation
- 10
- Posts
- 3
Update: It's working!
After reinstalling windows again didn't seem to help, I unplugged the PC from the wall to let the BIOS do a full reset. Left it like that for ~25 minutes, booted up, and bam! Wifi and Bluetooth both showing up. Wifi is working great, haven't tried the Bluetooth pairing again yet. Guess it was some glitch in BIOS somewhere. Hopefully this might help if someone else has the same problem.
03-25-2017 09:57 PM #5Moderator Array Nate152 PC Specs
- Join Date
- Feb 2013
- Reputation
- 404
- Posts
- 17,790
Great to hear you got it working !
The PCI Simple Communications Controller with a yellow triangle means the MEI driver isn't installed, you only need if using AI Suite.
11-20-2017 07:12 PM #6New ROGer Array
- Join Date
- Oct 2012
- Reputation
- 10
- Posts
- 2
ASUS Z270 Z270i Z270E Bluetooth Problem
You are not the individual case, I searched online and found many different cases from different regions/Languages with exactly the same Problem, Bluetooth disappeared for no reasons and nothing works on recovering until cutting off the power from the Motherboard, e.g: Unplug the Main Power for some time until the LEDs on motherboard goes off then Power it backup again, The problem will be temporary fixed, or Clear CMOS will do the same trick. Some Z270i Owners also reported other Bluetooth related issues such as Bluetooth devices can not be paired etc which can be resolved using the CUT-Power trick. See References Linked Below:
https://rog.asus.com/forum/showthrea...how-I-fixed-it
https://linustechtips.com/main/topic...0i-windows-10/
http://www.hyr5.com/f4/t25319
https://rog.asus.com/forum/showthrea...working-at-all
https://linustechtips.com/main/topic...luetooth-gone/
https://www.tonymacx86.com/threads/s....216999/page-2
https://www.reddit.com/r/ASUS/commen...h_not_working/
https://www.reddit.com/r/buildapc/co...denly_stopped/
And Maybe this:
https://rog.asus.com/forum/showthrea...er-or-settings
Most of the cases were on ASUS Z270i Users, but also reported by other ASUS Z270 (Z270E etc.) Motherboard Users, So ASUS, Please fix your stuffs.
