Results 1 to 7 of 7
03-25-2017 06:51 PM #1
IvanCabido PC Specs Motherboard Asus ROG Maximus IX Formula Processor Intel Core I7-7700K 4.2GHz Memory (part number) G.Skill Ripjaws V Red DDR4 3000 PC4-24000 16GB 2x8GB CL15 Graphics Card #1 Asus ROG Strix Geforce GTX 1070 Gaming OC 8GB GDDR5 Monitor Samsung Storage #1 kingston ssdnow 120gb m.2 sata Storage #2 Samsung 850 Evo SSD Series 500GB SATA3 CPU Cooler NZXT Kraken X52 Case Cooler Master MasterCase Pro 6 Azul Power Supply Corsair RM850i 850W 80 Plus Gold Modular Keyboard Microsoft Mouse Microsoft OS Windows 10 pro 64
- Join Date
- Mar 2017
- Reputation
- 10
- Posts
- 16
Doubt Dual Intelligent Processors 5
Hello, you know if the program Dual Intelligent Processors 5 when clicking on 5-way Optimization the program overclocking on motherboard + processor + ram + graphics card? Or on graphics card no) should I overclock the graphics card with another program? What do you advise me?
Cooler Master MasterCase Pro 6 Azul + Asus ROG Maximus IX Formula + Intel Core I7-7700K 4.2GHz + Asus ROG Strix Geforce GTX 1070 Gaming OC 8GB GDDR5 + G.Skill Ripjaws V Red DDR4 3000 PC4-24000 16GB 2x8GB CL15 + Samsung 850 Evo SSD Series 500GB SATA3 + Kingston M.2 SATA SSD 120GB + NZXT Kraken X52 + Corsair RM850i 850W 80 Plus Gold Modular.
03-25-2017 09:19 PM #2
JustinThyme PC Specs Laptop (Model) G752VY-DH72 Motherboard Rampage VI Extreme Processor I9 9940X Memory (part number) 64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17 Graphics Card #1 ASUS Strix 2080Ti O11G @ 2.1GHz Graphics Card #2 ASUS Strix 2080Ti O11G @ 2.1Ghz Graphics Card #3 ROG Nvlink Graphics Card #4 Have to feed animals Sound Card External Audioengine D1 24 bit 192kbps DAC Monitor ASUS PG348Q @ 100Hz Storage #1 Intel 905P 480GB U2 flavor Storage #2 Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1 CPU Cooler HeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS Case Phanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM Power Supply Corsair AX 1500i Keyboard ASUS Claymore Mouse ASUS Spatha, Logitech MX Master Headset Sennheiser HD 700 Mouse Pad ASUS ROG Sheath Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub OS Win10 Pro 1809 Network Router NetGear NightHawk X10 Accessory #1 NetGear Prosafe 10GBe Switch Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
- Join Date
- Nov 2013
- Reputation
- 144
- Posts
- 3,854
I wouldn't use the 5 Way optimization to OC anything. You can get much better results reading one of he OC guides and doing it from the BIOs
The 5 way doesn't do anything with the GPU, Download GPU tweak from your cards support site and use that.
On the GPU it's pretty easy. Start by moving the voltage to max, power to max.
Bump up the core about 10 at a time and run heaven bench. If it passes without crashing bump it some more and run again. Keep going until it crashes. The program will just close usually. Then dial or back a notch. Once you have that then move on to the vram slider and do the same.*
03-25-2017 10:19 PM #3
- Join Date
- Mar 2017
- Reputation
- 10
- Posts
- 16
Thanks for replying on the two threads JustinThyme, I will do as I indicated configure from ASUS GPU TweakII the graphics card. I understand you do not advise me to use Dual Intelligent Processors 5 to perform OC ?.
03-26-2017 03:29 PM #4
- Join Date
- Nov 2013
- Reputation
- 144
- Posts
- 3,854
03-27-2017 10:18 AM #5
- Join Date
- Mar 2017
- Reputation
- 10
- Posts
- 16
Thank you JustinThyme
03-27-2017 10:23 PM #6
- Join Date
- Oct 2012
- Reputation
- 339
- Posts
- 15,247
03-29-2017 06:04 PM #7
- Join Date
- Mar 2017
- Reputation
- 10
- Posts
- 16
