03-25-2017 07:10 PM - last edited on 03-05-2024 10:36 PM by ROGBot
03-26-2017 01:29 AM
03-28-2017 04:55 PM
03-28-2017 11:01 PM
04-03-2017 02:10 PM
04-04-2017 11:49 AM
04-04-2017 04:58 PM
04-05-2017 04:06 AM
Ymzuki wrote:
This seems strange, didn't see any similar problem on this forum,try changing to maximum performance or balanced in W10, see if there's any results, also try prime 95 benchmark , see if you get above 800MHz. If the problems is still there, contact ASUS and request RMA - maybe we're talking about a faulty CPU/motherboard?
04-05-2017 04:18 AM
Nightwing113 wrote:
I have had this problem with an old Dell notebook. I was able to solve it and get normal clocks, through disabling BD-Brochot with Throttlestop.
Note that this is the only solution I have found, and it is not optimal in an yway. IF you disable BD-Brochot and your laptop get too hot the CPU will not throttle. instead, it will thermally shutdown on 100c.
