Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    New ROGer Array
    Mar 2017
    3
    Problems with audio Z270E :(
    You are experiencing no audio problems with the realtek driver version 6.0.1.7997
    The sound sucks.
    Video demonstrating the problem.
    Is this a common problem?
    I7-7700K
    ROG Strix Z270E
    32gb Corsair V. Led
    Windows 10 Pro 64
    New ROGer Array
    Mar 2017
    1
    Also having the same problem. Actually came here to post this.
    i7-7700k
    ROG 270i Strix
    16gb Corsair LPX
    Windows 10 Pro 64
    using the latest realtek driver package from ASUS with the additional software.
    Running headphones with no amplification through the front panel, nothing hooked up to rear I/O.
    New ROGer Array
    Mar 2017
    3
    Quote Originally Posted by zer0xp View Post
    i7-7700k
    ROG 270i Strix
    16gb Corsair LPX
    Windows 10 Pro 64
    The front output is with much noise and the sound is increasing and decreasing.
    In your Z270I the same thing happens to the VIDEO I posted?
    Sorry for not knowing English properly.
    Thank you!
    I7-7700K
    ROG Strix Z270E
    32gb Corsair V. Led
    Windows 10 Pro 64
    ROG Member Array mikeymontz PC Specs
    mikeymontz PC Specs
    Motherboardz270 code
    Processor7700k
    Memory (part number)16gb rgb trident z 3200mhz
    Graphics Card #1gtx 980
    Monitorasus rog swift 27 vanilla
    Storage #1samsung 960 evo
    Storage #23 other sata hdd and a 2tb mech for storage
    CPU Coolernzxt x52
    Casecorsair 600t/ nzxt s340 elite
    Power Supplycorsair rm1000
    Keyboard razer bw te
    Mouse razer mamba te
    Mouse Pad a big black and red map mousepad from amazon
    Headset/Speakers yamaha cr3020 receiver with 2 big ass speakers
    OS win 10 pro 64bit
    Accessory #1 beer
    Accessory #2 booze
    Accessory #3 b*tches
    Mar 2017
    23
    same issue front panel distortion. rear working fine..
    i have the same problem on z270 code.... windows reinstall didnt fix it.... dunno what to do
    ROG Member Array
    Feb 2017
    15
    haus baviera
    There's another thread with the same issues:
    https://rog.asus.com/forum/showthrea...-Driver-Issues
    I opened a ticket with ASUS on this issue and finally got a completely unhelpful response after 25 days asking me to do things I stated I already did. Will be waiting another month for the next response Im guessing.
    New ROGer Array
    Sep 2017
    2
    Found a Solution
    Quote Originally Posted by renatomv10 View Post
    The sound sucks.
    I7-7700K
    ROG Strix Z270E
    32gb Corsair V. Led
    Windows 10 Pro 64
    After many trials and errors, I finally found a solution to the z270e audio issues. There are thousands of people having this issue and I am so glad to say I finally discovered the issue and have a fix. If anybody is still following this thread, I would be more than happy to post screenshots of the fix here on the forums. If you are still following, just post a comment quoting this message and I will post the screen shots and an explanation on how to fix the audio issues. If nobody is following this thread then I will not bother taking the time to do so. Please let me know. Thanks
  7. #7
    ROG Guru: Black Belt Array toronto699 PC Specs
    toronto699 PC Specs
    Laptop (Model)G752-VY-DH78K , G751-JYDH72X
    MotherboardRog Tytan G30AB
    Processori7-4770K
    Memory (part number)32GB
    Graphics Card #1Asus Gold20th GTX980Ti
    Sound CardDell X-Fi Audigy SoundBlaster
    Monitor3 Acer K272HL
    Storage #1118 GB/OS
    Storage #22.72 TB
    CPU CoolerIntegrated Liquid-Cooled CPU
    CaseG30AB
    Power SupplyAsus 700 Watt
    Keyboard Razer BlackWidow Ultimate
    Mouse Razer Diamond Back
    Headset Sony Studio Professional , Razer Seiren Mic
    Mouse Pad Razer FireFly
    Headset/Speakers Logittech 5.1 Z-5500
    OS W 10
    Network RouterSagemon Fast 5250 Hub 2000
    Aug 2014
    96
    2,494
    please post fix
  8. #8
    New ROGer Array
    Sep 2017
    2
    z270e Audio Fix
    Quote Originally Posted by toronto699 View Post
    please post fix
    The problem I discovered is: I believe the realtek audio drivers for the ASUS motherboards are constantly trying to combine the rear speaker outputs and the front headphone outputs. Realtek seems to want them to run at the same time and instead just turns down the rear audio outputs jacks instead of actually muting them when you plug in headphones in the front audio output ports. Here's what I did: I messed around with the settings and found an interesting fix that splits up the two outputs into just rear speakers and front headphones instead of trying to combine them as one audio output.
    When you open Realtek HD Audio, you will see this main screen.
    In the top right hand corner, there is a cogwheel for options. Click the cogwheel and click on "Option".
    After you get into the "Options" menu, there will be a box that says: "Make front and rear output devices playback two different audio streams simultaneously". Check the box and press"OK" in the bottom right of the menu.
    After that, when you return to the main Realtek menu, you should see that you now have settings for both "Speakers" and "HD Audio 2nd Output" (This is what it named them on my pc, the names could be different for you depending on your speakers, headphones, and drivers for your audio devices. You can also see this in effect in the first image of this post.) I can now successfully adjust my volume levels to any value without the popping and crackling sounds. My rear speakers also sound fine now as well.
    This is the fix that solved my audio issues with the z270e ASUS motherboard. If it does not work for you the first time, I discovered that you may have to check and uncheck the box and press "OK" again. I simply messed around with the "Options" menu until I found out that it was combining my speakers and headphones as one audio output. If this does not work for you, please let me know and I will work on finding another fix. Thank you and best of luck with this fix.
  9. #9
    New ROGer Array
    Apr 2017
    1
    I had the same problem with audio changing between low and high. I got the ROG STRIX Z270E GAMING and Windows 10 64Bit. After installing the driver version 8090 from the support website (https://www.asus.com/de/Motherboards...Desk_Download/) under audio the problem was solved and i had no further issues with the sound. So maybe this helps someone.
  10. #10
    ROG Guru: White Belt Array
    Jul 2017
    6
    94
    I had same issue, I uninstalled all the asus software including ai suite and uninstall realtek and let windows install its own driver. rebooted to safe mode used guru3d DDU tool to clean remove vid driver. installed latest video driver from nvidia unchecking hd audio install. rebooted then installed latest audio drvier from asus site, and no more crackling.
    I was already using the latest driver from asus, so maybe windows update sometimes corrupts them. Or maybe sometimes the asus software gets glitched after a while. Not sure. But definitely software issue. For a bit I thought my board was going bad. But I doubt now thats the case.
