Results 1 to 5 of 5
Thread: AURA is lagging
    ROG Member Array Findolin PC Specs
    Findolin PC Specs
    MotherboardAsus Maximus IX Hero
    ProcessorIntel i7-7700K
    Memory (part number)G.Skill Trident Z RGB 16GB DDR4-3600
    Graphics Card #1Asus Strix GTX 1070 OC
    MonitorAsus PG278QR
    Storage #1Samsung 960 Evo 500GB NVMe SSD
    Storage #2Seagate Barracuda 3TB HDD
    CPU CoolerNZXT Kraken X62
    CasePhanteks Eclipse P400S TG
    Power Supplybe quiet! Straight Power 10-CM 700W
    Keyboard Logitech G910 Orion Spark
    Mouse Logitech G600
    Headset SteelSeries Arctis 7
    OS Windows 10 Pro x64
    Mar 2017
    15
    AURA is lagging
    Hey, i have an issue with AURA on my Maximus IX Hero.
    If i set the lighting settings in the software to something dynamic, it will always lag for some seconds.
    Example: If i set the settings to "comet", the cycle will stop at some point (RAM or LED strip most of the time) and stay there for like 1-2 second. after that it goes on. that happens in almost every sequence. Same behavior for "flash and dash", "strobing".
    The following parts are involved:
    Maximus IX Hero
    GTX 1070 Strix
    Phanteks P400S TG + RGB Strip (connected to RGB_header 1)
    The LED control of the case is turned off (of course)
    Any ideas on this issue?
    Findolin PC Specs
    MonitorAsus PG278QR
    Mouse Logitech G600
    Mar 2017
    15
    No ideas on this issue?
    ROG Member Array We Gone PC Specs
    We Gone PC Specs
    MotherboardASUS Hero Alpha
    ProcessorI7 6700K @ 4.5 @1.312v
    Memory (part number)Corsair 3200 4x8 @ 3300
    Graphics Card #1GTX1070
    MonitorPG279Q & 226BW
    Storage #1Sansung 850 500gb SSD
    Storage #22TB Seagate
    CPU CoolerApogee Drive II
    CaseCM Stryker
    Power SupplyEVGA P2-o750-X1
    Keyboard Logitech G810
    Mouse Logitech G502
    Headset/Speakers Logitech 5.1 X-540
    OS W10
    Aug 2016
    13
    9
    Good Luck, I can't get it to save setting, every time I reboot I have to reset the colors I had chosen......Can't count how many times I have un-install and re-installed.. Unfortunately I just turn it off now!!
    I go back to the 8088 days.... Asus MB's, P5N32-E SLI Q6600, Rampage Formula X48 still running @ 3.5, Maximus VIII Hero Alpha.
    Findolin PC Specs
    MonitorAsus PG278QR
    Mouse Logitech G600
    Mar 2017
    15
    Thanks for your answer!
    Turned out it's the CAM software (v 3.3.1) i am using with my NZXT Kraken X62 causing this problem.
    If the program is completely closed from the taskbar, everything works fine.
    I should have suspected that earlier, since there a so much more problems with CAM. This software is a piece of trash.
