Results 1 to 10 of 30
Thread: Q-code error 0d - Crosshair VI
04-04-2017 02:32 PM #1ROG Member Array
- Join Date
- Feb 2015
- Reputation
- 10
- Posts
- 20
Hello all,
I received my back-ordered MOBO and put my new computer together but can not get it to POST. I assembled and tried to boot but get Q-code:0d and can not get to BIOS. The MOBO light up RGB and appears to be on; the amber light indicating a problem with DRAM is lit. CPU light is green (ready).
BUILD:
ASUS Crosshair VI
Ryzen 1800X
G.Skill F4-3200C14D-16 (2x8GB)
Samsung 960 Pro.
Asus Strix GTX960 OC 2GB
Corsair CX750M (24-pin and 8-pin; no 4-pin)
Fractal Define R5
Dark Rock Pro 3
I tried the shipped BIOS first: Q-Code: 0d.
I updated to latest BIOS via USB and back button: Q-Code: 0d.
Loosened the back plate to the CPU cooler (removed and re-seated all components): Q-code Od.
Tried to clear the CMOS with button on back: Q-code: Od.
Unplugged the USB 3.0: Q-code: 0d.
Tried all RAM slots and each separately (both RAM bad?): Q-code: 0d (on all combinations).
UPDATE: I went to Best Buy and bought PNY Anarchy 2x8GB 2133 CL15 and tried each of the RAM stick and got the same result as above: Q-code: 0d.
UPDATE 2: Tried both BIOS 0902 and 1002.
Update 3: Purchased PNY Anarchy (2x8) 2133MHz (not QVL) and the result did not change: Q-code: 0d.
UPDATE 4: I removed the original backplate for the new cooler and reused the thermal pad so I disassembled and tried again without the pad and no change: Q-code: 0d.
UPDATE 5: I called ASUS and went through the basic steps above but this time without the video card.... same result: Q-code 0d. They recommended RMA. Returning to Amazon (quicker).
*****EDIT 4/7/17- I received a second Crosshair VI and assembled the computer. I updated BIOS to 1002 before all else and can access BIOS. I then attempt to install WIN10 but as soon as the splash screen comes up the install freezes. I cannot populate DIMM_A2 slot with any memory and get Windows to boot. (The RAM is detected in BIOS but I am getting Q-code 54 & 55 and can not install Win10 and once installed will not boot as long as DIMM_A2 is populated; either stick of G.SKill works in DIMM_B1 & B2 or I can run two sticks in single-channel mode as long as DIMM_A2 is not populated. DIMM_A2 would not accept the PNY Anarchy 2133 (non-QVL). I tried to set the RAM speed in BIOS (not AUTO) and no change.
BOTTOM LINE: All the RAM I began with works. I get the same Q-code: 0d when 2nd MOBO DIMM_A2 is installed. WIN10 would not load OS and once installed will not boot as long as DIMM_2 is populated (BIOS sees it with 54 and 55 code and wont boot).*****
Any suggestions?
Thanks in advance.Last edited by Teramungus; 04-07-2017 at 01:56 PM. Reason: Update
04-05-2017 01:51 AM #2ROG Guru: Yellow Belt Array Demoniacstar PC Specs
Demoniacstar PC Specs Laptop (Model) none Motherboard Asus Crosshair VI Hero Processor Ryzen 1800x Memory (part number) tdrgd4 16g3000hc16cdc01 Graphics Card #1 XFX R9 390/ EK water block OC'd Graphics Card #2 XFX R9 390/ EK water block OC'd Sound Card on board Monitor 2X 24" veiwsonic 1080p/ 55"Samsung 4k curved Storage #1 Samsung evo 840, 250gig sys drive Storage #2 5 other mixed hdd's CPU Cooler EK C6H mono block Case Thermaltake core x9 Power Supply Thermaltake 1500w dps rgb Keyboard Corsair k65 Mouse R.A.T. 9 Headset Turtle Beach Star Wars X wing edition Mouse Pad WOW desk mat Headset/Speakers Logitech 5.1 Accessory #1 Airplex radical 2 480 on gpus swifttech d5 Accessory #2 Airplex radical 2 480 on cpu swifttech d5 Accessory #3 Airplex radical 2 280 on sb p500 TT
- Join Date
- Nov 2014
- Reputation
- 10
- Posts
- 162
as i have said in another post.....
maybe i should rename it ?...lol
any way ....boot up ..let it do what it do ......when you get the 0d code ...hit the reset to bios button and immediately press and hold the red start button on motherboard when Qcodes light up release the red start button it will boot to bios
04-05-2017 01:56 AM #3ROG Guru: Yellow Belt Array Demoniacstar PC Specs
- Join Date
- Nov 2014
- Reputation
- 10
- Posts
- 162
get ready to do alot of reading if you're new to tuning your pc...of course stock settings are decent but strangely overvolted and you get better performance by locking the cpu clock speed and tuning ram as high as you can
some ram is still finky in these boards..these boards and cpu's are to ....but that's going to improve tremendously from what we got now as far as stability goes ...some say the performance won't change... i say put on your seatbelt and hold on this trains not up to speed yet....lol...
04-05-2017 10:53 AM #4ROG Guru: Brown Belt Array MeanMachine PC Specs
MeanMachine PC Specs Laptop (Model) I enjoy my wife Motherboard CVI HERO + CVII Hero Wifi Processor Ryzen 7 1800X + 2700X Memory (part number) CMD16GX4M2B3000C15 + F4-3200C14D-16GTZR Graphics Card #1 EVGA GTX980 SC for CVFZ Graphics Card #2 EVGA GTX 1080 hybrid Graphics Card #3 GTX 770 for phys x Sound Card MB Monitor HP w2408h Storage #1 Samsung 970 EVO 500GB M.2 Storage #2 Samsung 840EVO 500GB and 960 M.2 pro CPU Cooler Corsair H105, H110 and H115i Case Corsair 750D and 780T Power Supply Corsair AX-1200i and Antec 850 pro platinum Keyboard Logitech K800 Mouse Razer Mamba Headset Corsair Vengeance 2100 OS W7 Ultimate 64bit and W10 pro 64bit Network Router Netcom Wireless NF18ACV
- Join Date
- Apr 2014
- Reputation
- 126
- Posts
- 1,698
Hope you don't mind me jumping into your thread Teramungus but it seemed appropriate.
Your not the only one with Qcode 0d
Iv'e tried everything like you and hope one of the techo's can explain just what Qcode od stands for. It's not listed in my manual.
I have the same MB and CPU and have tried what Demoniacstar said to do Quote: .boot up ..let it do what it do ......when you get the 0d code ...hit the reset to bios button and immediately press and hold the red start button on motherboard when Qcodes light up release the red start button it will boot to bios. Still no go.
Will try again tomorrow with a Bios change. I'm on Bios 1002 so will try 0902 and keep fingers crossed.
Anyhow the MB lights up, CPU and radiator fans seem OK, graphic card working, have a good working PSU.
I'm trying Corsair Dominators CMD16GX4M2B3000C15 and I hope that's not the issue. Tried switching modules in different slots too.
I don't think this is RMA time just yet even if ASUS support says so. Still a few things to try in bench mode.
Hang in there and see if anything comes up in the next few days.We owe our existence to the scum of the earth, Cyanobacteria
My System Specs:
MB:ASUS ROG Crosshair VII Hero/WiFi GPU:EVGA GTX 1080 sc PSU:Corsair AX-1200i
CPU:AMD R7 2700X Cooler: Corsair Hydro H115i Case: Corsair Carbide 780t
Memory:G.Skill TridentZ F4-3200C14D-16GTZR SSD:Samsung 500GB 960 EVO M.2
04-05-2017 01:00 PM #5ROG Member Array
- Join Date
- Mar 2017
- Reputation
- 10
- Posts
- 22
04-05-2017 01:35 PM #6ROG Member Array
- Join Date
- Mar 2017
- Reputation
- 10
- Posts
- 5
Got the Same Problem ...
Are you using the Display Port on the Graphics Card?
Try it again on a HDMI - Port.
This is what my Error was. It should work on a DVI too.
Have a lot of grey hairs more now - because this Error confuses me. My Computer still wont work on DisplayPort with BIOS1002. But HDMI is doin it for me in the meantime. Im writing on that Machine,..Last edited by CCarpenter; 04-05-2017 at 01:45 PM.
04-05-2017 06:31 PM #7ROG Guru: Yellow Belt Array Demoniacstar PC Specs
- Join Date
- Nov 2014
- Reputation
- 10
- Posts
- 162
to get a displayport working on your graphics card at boot all you have to do is disable csm completely in bios
and you don't have to disconnect anything when you can't boot ....try what i said ....it works...and works every time for me ....
hit reset to bios and immediately!! press and hold the start button in until you see the q codes light up then let go ...it will always no matter what go to bios on my board when i do this, it even gets passed the dreaded 8 code
04-05-2017 07:16 PM #8ROG Member Array
- Join Date
- Feb 2015
- Reputation
- 10
- Posts
- 20
Thanks to all!
I hope someone finds this thread useful and does not have to go through RMA.
I never got a chance to try your method. Amazon is sending a new one overnight and I tore computer down to ship before your responses.
I was using HDMI.to get a displayport working on your graphics card at boot all you have to do is disable csm completely in bios
If I have any problems with the new board I will try the following:Thanks Demoniacstar... and again, thanks to all!hit reset to bios and immediately!! press and hold the start button in until you see the q codes light up then let go ..
04-05-2017 07:44 PM #9ROG Member Array
- Join Date
- Feb 2015
- Reputation
- 10
- Posts
- 20
So, I am curious as to what you do after you enter BIOS to prevent going through this method every time you boot. Does it go away when an OS is installed? Are settings changed in BIOS?
Another question to all: Was your yellow DRAM light lit (right below the Q-code display)?
04-05-2017 08:08 PM #10ROG Guru: Yellow Belt Array MNMadman PC Specs
MNMadman PC Specs Motherboard Asus ROG Crosshair VII Hero (Wi-Fi) Processor AMD Ryzen R7 2700X Memory (part number) G.Skill F4-3200C14D-16GTZRX 2x8GB Graphics Card #1 Nvidia TITAN Xp Jedi Order Collectors Edition Monitor Acer XB270HU 27" 1440p 144Hz G-Sync Storage #1 Samsung 960 Pro 2TB NVMe CPU Cooler Custom Liquid Cooling Loop Case PrimoChill Praxis WetBench White/Black Power Supply Corsair HX1000i Keyboard Logitech G Pro Mouse Logitech G Pro Headset Logitech G633 Mouse Pad Logitech G440 OS Windows 10 Pro 1803
- Join Date
- Jan 2016
- Reputation
- 12
- Posts
- 146
