Microsoft ACPI-Compliant System help please :)
Bodycount69
I have just built two systems using the same motherboard and i'm having the same problem on both systems.
Under Device Manager , Other devices, I have a " Unknown device " right click on it and go to properties its Microsoft ACPI-Compliant System The drivers for this device are not installed. (Code 28) There are no compatible drivers for this device. To find a driver for this device, click Update Driver. Click update driver and it won't find anything.
My system info below:
Asus ROG PG348Q Black 34" 3440 x 1440, 100Hz Curved IPS G-Sync 21:9 WQHD Gaming Monitor
Corsair Graphite Series White Steel 780T Full Tower PC Case
CORSAIR HXi Series HX1200i 1200W 80 PLUS PLATINUM Full Modular Power Supply
ASUS ROG STRIX X99 GAMING LGA 2011-v3 Intel X99 Motherboard
CORSAIR Dominator Platinum 128GB (8 x 16GB) 288-Pin DDR4 SDRAM DDR4 2666 (PC4 21300) Desktop Memory
Intel Core i7-6900K 20M Broadwell-E 8-Core 3.2 GHz LGA 2011-v3
Corsair Hydro Series H110i Extreme Performance Water / Liquid CPU Cooler Cooling
2x SAMSUNG 850 EVO 2.5" 1TB SATA III 3-D Vertical Internal Solid State Drive
2x ASUS GeForce GTX 1080 8GB ROG STRIX OC Edition in SLI
ASUS - MOTHERBOARDS 2-WAY SLI BRIDGE 2-WAY SLI BRIDGE COMPATIBLE
LG Black 16X BD-R 2X BD-RE 16X DVD+R 5X DVD-RAM 12X BD-ROM 4MB Cache SATA Blu-ray Burner
Upgraded All fans to : Thermaltake Ring 14 Series High Static Pressure 140mm Circular Red LED Ring Case/Radiator Fan
Logitech G910 Orion Spark USB Mechanical Gaming Keyboard
Logitech G502 Tunable FPS Optical Gaming Mouse
SteelSeries Siberia 840 wireless gaming headset
SteelSeries QcK Heavy Mousepad
Windows 10 64Bit
0 REPLIES 0
