04-05-2017 09:58 AM - last edited on 03-05-2024 10:31 PM by ROGBot
harrysun on 5th of April 2017 wrote:
Prime95 stable 1.5h: @DDR4-2666 CL14-13-13-32-63-1T 1.350V
AMD Ryzen R7 1800X @3975MHz, Stepping 1 Revision ZP-B1
ASUS ROG CROSSHAIR VI HERO, BIOS 1002 03/24/2017
DDR4-3200, CL14-14-14-34-48 1.350V Ranks:2 (2R)
Motherboard Slots: DIMM_A2, DIMM_B2
04-16-2017 06:38 PM
harrysun wrote:
I'm using this DDR4 kit G.Skill Trident Z DIMM Kit 2x16GB (F4-3200C14D-32GTZ) successfully with following configuration
04-18-2017 02:40 AM
04-18-2017 01:36 PM
poisson21 wrote:
I have 2 kit of this RAM, at the moment i can run them at 3200 Mhz with my 1800x, bios 083.
101*40.25 bclk.
1.375 dram and dram boot.
Soc 1.0v
cpu v 1.45 +llc3.
strap 3200 Mhz.
But i can't lower my timming, atm 18-16-16-16-36.
If you want to train your ram , start with 2666 strap, with loose timing (18-16-16-16-36) once, restart, choose 3200 strap , restart, see if there is any effect,
if yes, you can try after that to lower your timing, one at a time.
04-18-2017 07:35 PM
101*40.25 bclk.
Soc 1.0v
cpu v 1.45 +llc3.
strap 3200 Mhz.
04-23-2017 01:45 AM
04-23-2017 10:53 AM
harrysun wrote:
For me ProcODT = 96 Ohm was the key to succeed.
