Results 1 to 2 of 2
    ROG Enthusiast Array bfollowell PC Specs
    bfollowell PC Specs
    MotherboardASUS ROG Maximus IX Hero
    ProcessorIntel Core i7-7700K
    Memory (part number)G.SKILL TridentZ Series 16GB DDR4 SDRAM DDR4 3200 (PC4 25600) F4-3200C16D-16GTZB
    Graphics Card #1ASUS ROG Strix GeForce GTX 1080 OC edition 8GB 11Gbps ROG-STRIX-GTX1080-O8G-11GBPS
    Sound CardSound BlasterX AE-5
    MonitorASUS ROG Swift PG279Q & ASUS VW246H
    Storage #1Samsung 850 EVO Series 500GB 2.5" Solid State Drive
    Storage #2Western Digital Black Series 2TB 3.5" 7200RPM Hard Drive
    CPU CoolerNZXT Kraken X61
    CaseCorsair 750D
    Power SupplyEVGA 750 G3
    Keyboard Logitech G710+
    Mouse Logitech G602
    Headset Kingston HyperX Cloud Pro
    Headset/Speakers Logitech G​51 Surroun​d Sound 5.​1 Speaker ​System
    OS Windows 10 Home 64-bit
    Network RouterLinksys WRT3200ACM
    Jan 2017
    64
    FreeSync/G-Sync monitor newbie question
    I am still planning out my new gaming build that I will be putting together later this year, likely in the fall. Originally, I had planned to continue using the Asus 24" VW246H I've been using since 2010 as it's still a great monitor and I've been fine with 1080P. Still an i5-7600K and a GeForce GTX 1070 seems sort of overkill for 1080P gaming. So, I've been giving a lot of serious thought to adding a 27" 1440P gaming monitor to my build. I've read up a little on FreeSync and G-Sync monitors and I think I have a decent idea about the theory behind them. I'm a die-hard Nvidia fan and have used nothing but Nvidia based cards since retiring my old Canopus Pure3D II Voodoo2 SLI setup back around 2000. I'm assuming that, in order to benefit from their features, as an Nvidia user, I'd pretty much have to get a G-Sync monitor, correct? If I picked up a FreeSync monitor instead, the Asus MG279Q for instance, I'd get absolutely no benefit from its FreeSync technology since my Nvidia card and its drivers aren't setup to use them. Is that pretty much correct?
    If that's the case, I'll probably be looking at the Asus ROG Swift PG278QR, but it is considerably more expensive.
    I'm just trying to plan and budget accordingly.
    Thanks.
    ROG Guru: White Belt Array
    Feb 2013
    90
    Canopus. There's a name I haven't heard for a while. They made such nice cards. And yes since you are sticking to NVIDIA cards then you will need a G-Sync monitor to make use of the feature. A Freesync one will work fine with an NVIDIA card but you will not be able to use the 'Freesync' feature of the monitor, as a G-Sync monitor will work fine normally with an AMD card but you will not be able to use G-Sync with one. So plan on something like the PG278QR you mention. G-Sync monitors work very well but do run more on the expensive side.
    GL
