Results 1 to 3 of 3
Thread: Maximum Fan RPM
    ROG Member Array
    Dec 2016
    21
    Maximum Fan RPM
    Hello,
    I'm having an issue with one of my fans. I have a Noctua Industrial PPC 3000 RPM, 12V PWM that was working just fine with my old Crosshair V Formula Z goes up to 3000 RPM (quite noisy and noticeable but giving a lot of pressure).
    Now with the C6H the maximum speed it reaches is about 1500-1600 RPM no matter how I set it through the BIOS - PWM or Voltage mode, turned off the power management, maxed it out, nothing helps. The fan is connected to OPT 2 as it's closes to the front panel.
    Any ideas what could be wrong?
    untouched Array Praz's Avatar
    Apr 2011
    137
    4,038
    Quote Originally Posted by injurer View Post
    Hello,
    Hello
    I'm not sure what OPT 2 is. If you are referring to the CPU_OPT header it is slaved to the CPU_FAN header and cannot be configured independently.
    ROG Member Array
    Dec 2016
    21
    My mistake. It's actually CHA FAN 2.
