Help with G-SkillF4-4000C19D-16GTZKW
Goons1981
Hello all!
Just installed my new Crosshair x370 system today. Question, i can't seem to get a good ram overclock on this ram kit.The most i can get is 2933mhz . I have tried changing the timings to the similar flare X 14 14 14 14 34 no dice, i have even tried looser timings and upping dram voltage and soc voltage and it does not help. Iam not expecting 4000mhz oc i just want at least 3200mhz. 😞
FuryA
hi Goo , welcom
Try to update the new BIOS version >1002 and
what is Your R7 cpu? Can You try different or raise the voltage
MNMadman
Unfortunately, even the "best" RAM sometimes cannot get 3200 speed. Just letting you know that -- you might have to settle for 2933 for now.
What RAM and SoC voltages did you try? You may need to increase them further. Also, did you increase the DRAM Boot voltage (last setting in Digi+ menu)?. It should match your RAM voltage.
What BIOS are you running? That can affect things as well.
