Results 1 to 9 of 9
    ROG Member Array
    Mar 2016
    7
    HELP! Spilt water on laptop!!
    Help!
    Spilt water on laptop and it's still wet inside 2 days later. I left it to dry and then decided to open it and there's a lot of moisture inside (under keyboard).
    Any advice on how to save it?*
    ROG Member Array MasterScythus PC Specs
    MotherboardASUS Maximus IX Hero
    Processori7-7700k @ 4.2GHz
    Memory (part number)Corsair Vengance LPX 16GB DDR4-3000MHz
    Graphics Card #1ASUS STRIX 1080 OC
    MonitorASUS VG248QE
    Storage #1Samsung 850 EVO 250GB SSD
    Storage #2Samsung 850 EVO 250GB SSD
    CPU CoolerCorsair H100i v2
    CaseNZXT H440 Razer Edition
    Power SupplyCorsair CXM 750W 80+ Bronze Semi-Mod
    Keyboard Razer Blackwidow Chroma
    Mouse Razer Naga Epic Chroma
    Headset Razer Kraken Pro
    Mouse Pad Razer Goliathus
    OS Windows 10 Home
    Jun 2015
    6
    Quote Originally Posted by gordon86 View Post
    Help!
    Remove all power to the laptop. Disconnect all cables. Pull up your keyboard. There should be little rectangle notches you can use a very small screwdriver to pry it up. They should go across the top. Get what moisture you can out with q-tips, power towels, etc. When done, lay it down keyboard down on a towel and take your back panel off. You need to inspect the components on the underside. Do the same methods you used to clean the keyboard area out.
    ROG Guru: Diamond Belt Array Zka17's Avatar
    Mar 2012
    199
    8,359
    Disconnect all power, take it apart and have a fan blowing on it for 24 hours... - that if it was water... if it was more than water, then you have to wash it first...
    ROG Member Array
    Mar 2016
    7
    Thanks for the advice, I stupidly tried to switch it on without checking that it was totally dry, hopefully I haven't ruined it! Even over 48 hours later there was still a lot of moisture under the plastic film on top of the motherboard. Not sure how to lift this film up without breaking something.
    ROG Guru: Green Belt Array UltraNEO* PC Specs
    UltraNEO* PC Specs
    Laptop (Model)Dell XPS 13
    MotherboardAsus Rampage V Edition 10
    ProcessorIntel i7-6850k
    Memory (part number)G.SKILL F4-3600C17Q-32GTZR
    Graphics Card #1Titan X (Pascal)
    Graphics Card #2Titan X (Pascal)
    MonitorASUS ROG Swift PG279Q (x3)
    Storage #1Samsung 970 Pro 1TB NVMe
    Storage #2Samsung 860 Pro 1Tb (x4)
    CPU CoolerCustom Watercooled
    CaseCaseLabs SMA8
    Power SupplyCorsair AX1500i
    Keyboard Keyboard Paradise Custom
    Mouse Logitech G903
    Mouse Pad Logitech G840 XL
    Headset/Speakers ART SLA2 Linear Amp with JBL Control 5
    OS Win 10 Pro
    Network RouterPF Sense
    Accessory #1 Logitech Brio 4k
    Accessory #2 Logitech PowerPlay Game Pad
    UltraNEO*'s Avatar
    Dec 2011
    48
    605
    Oh ****..
    Never turn on electrical devices if they get wet. Better wait a week, remove the battery and air them somewhere warm. Some suggest covering the device in a pile of rice can help.
    ASUS ROG RVIE Encore| i9-10940x | Dominator Platinum 128GB 3333 MHz | EVGA RTX 2080 Ti SLI | Samsung 970 Pro 1TB NVMe (x3)
    WD Black 4TB | WD Black 6TB x2 | EVGA 1600 P2 | CaseLabs SMA8 | Custom Water Cooling | HWLabs Black Ice Nemesis GTX 560
    XSPC RX 480 v3 | XSPC D5 Vario x2 | EK Blocks | EK-RES X3 400 | BitsPower Fittings | GentleTypoon 1850 x12 | Corsair SP140 x8 | Lamptron CM615
    Twitch.tv/MsNikita | Twitter.com/MsNikitaTV | Instagram.com/MsNikitaTV | Reddit.com/r/MsNikitaTV
    ROG Member Array
    Mar 2016
    7
    Looks like it's ruined * took it to a repair place who said the motherboard is damaged
  7. #7
    ROG Guru: Green Belt Array panzlock PC Specs
    panzlock PC Specs
    Laptop (Model)ASUS X553M, ASUS Zenpad 10 Z300M, ASUS X542BA-DH99
    MotherboardASUS P8Z68-V LX, ASUS Z170-A, ASUS ROG Strix B350-F Gaming
    ProcessorIntel i5-2500K, Intel i7-6700K, AMD Ryzen R7 1700
    Memory (part number)8GB Kingston 1333MhzDDR3 C9, 16GB G.Skill Aegis 3000Mhz DDR4 C16, 16GB G.Skill Trident Z 3200Mhz C16
    Graphics Card #1EVGA GTX 560Ti, ASUS ROG Strix GeForce GTX 1070 O8G OC, Sapphire Nitro+ RX Vega 56
    Monitor32" INSIGNIA 720p, 32" Samsung 1080p C32F391FWN, 32" ASUS 1440p VA32AQ
    Storage #1Seagate 150GB 7200RPM, Samsung 850 EVO 250GB 2.5" 6Gb/s Solid State Drive (X2)
    Storage #2Seagate 500GB 7200RPM, WD Blue 3TB - 5400 RPM SATA 6 Gb/s 64MB Cache 3.5 Inch
    CPU CoolerDeepcool GAMMAXX 300, Deepcool Lucifer V2, Wraith Spire
    CaseAntec Sonata, Deepcool Dukase V1, Deepcool Dukase V3
    Power SupplyATX 650, EVGA SuperNOVA 850 P2 (X2)
    Keyboard Logitech K220, MSI Interceptor DS4200 (X2)
    Mouse Microsoft 1850, Microsoft 4500, Gamdias Erebos LE, MSI DS 100, Redragon M601 Centrophorus
    Headset/Speakers Logitech Z313, Logitech Z506 (X2)
    OS Windows 10 Home X64, Windows 10 Pro X64 (X2)
    panzlock's Avatar
    Nov 2016
    54
    701
  8. #8
    ROG Member Array
    Mar 2016
    7
    So does anyone have an idea how much I could get for the chassis and screen (in the UK)? Assuming screen will work as water only went on the keyboard.
    I guess there's a chance the CPU is OK but how to test it? I assume it's not as simple as pulling it out and sticking it in another laptop.
  9. #9
    ROG Member Array
    Mar 2016
    7
    Haha thanks for your concern panzlock
    Quote Originally Posted by panzlock View Post
Tags for this Thread
