Results 1 to 5 of 5
    ROG Member Array MichaelHansen PC Specs
    Laptop (Model)Alienware - Something
    MotherboardASUS Rampage V Edition 10
    Processori7-6950X
    Memory (part number)128GB G.Skill Trident Z (3200)
    Graphics Card #1Titan X Pascal
    Graphics Card #2Titan X Pascal
    MonitorAcer X34
    Storage #1Samsung Pro 950 512GB
    Storage #2Samsung Pro 850 1 TB
    CPU CoolerCorsair H115i
    CaseCorsair 760T
    Power SupplyCorsair AX-1500i
    Keyboard Corsair K70 - RGB LED - Cherry Brown MX
    Mouse Corsair M65 Pro RGB
    Headset Audio Technica
    Mouse Pad Corsair Gaming M400 (Medium)
    Headset/Speakers QSC KWs (Yes they are loud)
    OS Windows 10 - Pro - 64 Bit
    Network RouterFIOS Quantum Gateway
    Accessory #1 The good stuff
    MichaelHansen's Avatar
    Dec 2016
    17
    Extreme Wall Mounted Z270 – 1080Ti’s in SLI
    Hey Guys,
    So I am starting my 3rd build and the second extreme build of the year. In this build I selected the Z270 with a Thermaltake Core P3 case. (Yes the GPUs are limited to 280mms). That’s just enough room to run 2 x 1080 TI in SLI. Build has extreme sound as it will be used for entertainment, live music, DJing & VJing not to mention VR gaming.
    PC COMPONENTS:
    Case: Thermaltake Core P3
    Motherboard: ASUS Maximus IX Code
    RAM: G.Skill RGB 3600mhz 32 GB
    Drive: Samsung 960 Pro 512GB
    GPU’s: 1080TI’s �� (they are not founders edition)
    Sound: 2 x QSC KW181 Subs & 2 x QSC K12’s
    Displays: 3 x 55” LED TV’s & 1 x 46” LED
    Monitor: Acer Predator XB24
    I am breaking up the build in 3 videos as it coincides with a basement construction. Should be pretty cool as I will also be adding RGB Lighting to the case and room! Should have it assembled in the next few days.
    1st Video of Three Below:
    https://youtu.be/-6IllQJOdAY
    Thanks for the Tip Nate152
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,359
    Hi MichaelHanson
    We can't open your video, copy the URL and in the reply box click "insert video", paste it in there and click ok.
    Edit - Thank you that will work, It looks like yours is going to be a nice music machine as well as an awesome gaming machine. I play guitar and bass too.
    I see you don't have a cooler listed, be sure to get a decent one. The i7-7700k has good overclocking potential if Intel sends you a good one. Depending on your sample you may can hit 5.2GHz without delidding.
    Looking forward to seeing more of yours.
    Here is my Maximus IX Code and i7-7700k at 5.0GHz with Mafia III.
    Processori7-6950X
    MonitorAcer X34
    CaseCorsair 760T
    Dec 2016
    17
    Processori7-6950X
    MonitorAcer X34
    CaseCorsair 760T
    Dec 2016
    17
    Build Update: GPU's & PSU
    Decisions, decisions and decisions!
    Considering it's 4:20am EST and I may of done something crazy! I returned 2 x ROG 1080ti Stix's for 2 other GPUs that are minimalistic (if that is even a word)! LOL Yea! You read that right!! (you are not blind). The problem is the case dimensions and spacing limitations and I did not want to deal with PCIE risers. Therefore, with the radiator clearence and the over sized 1080ti they will not fit (which I already knew before buying them). That and I really don't think the ascetics of modding the case to move the radiator to right would work. In addition I allotted for just the right space on the wall as the case is flanked by 8 wall mounted guitars. I even thought of taking my Titan Xp in SLI from my 6950x build and swaping them with this build for the 1080ti Strix.
    In addition since so much lighting is going into the case I decided to simplify the GPU's. I also want almost everything blacked out except for the RGB lighting. That ruled out the EVGA SC2. The EVGA black was a good contender and so was the SC2 Elite in black. Nevertheless, I wanted to use the ROG SLI HB bridge (they look sexy!). So yea you guessed it I went with Asus 1080ti Turbos. (They even lack back plates). They operate at same speeds as the FE cards. But I liked the simple black look with out the over the top logo lighting from EVGA. To solve the black plate issue contacted V1 tech to have them build a custom black plate in black and smoked transparent accents for the ROG logos.
    Regardless, my indecisions didn't stop there. I originally intended to use a Corsair AX 860i with the build but ended up switching that out as well to the EVGA Plantnum 1000 watt PSU. Did this for several reasons I liked the dimensions as it left room for some additional components and I calculated my power draw to be 797 watts with out some of the USB peripherals that would be going into this build. So I ended up sending that back as well.
    Regardless, I am staring at all the components and will probably time lapse the build this weekend. Really excited about the lighting!
    Anyways had to rant.
    Kind Regards,
    - Mike
    Processori7-6950X
    MonitorAcer X34
    CaseCorsair 760T
    Dec 2016
    17
    PC Build is Done - Time Lapse Video
    All:
    Build is complete. This is the time lapse video for this build.
    https://youtu.be/oHXt4YHykhk
