Results 1 to 5 of 5
    ROG Member Array
    Mar 2015
    13
    Lightbulb Best way to go from w10 to w7 and back to w10 ?
    hi
    3 years ago i bought my ROG G751JT , it came with windows 8 OS , then i upgraded it to w10 like every1 else .
    it worked fine for 2 years , then i decided to go back to Windows 7 , i did but i didnt like it so i wanna go back again to windows 10
    now , should i install windows 8 then upgrade to windows 10 like i did in the first time ? or i should install windows 10 directly ?
    its bcoz of my serial number , i think its embded in the BIOS , so if i installed windows 10 ,, will it get activated ? or i should go w8 then upgrade to 10 ??
    any help is appreciated
    thank u
    ROG Enthusiast Array pigulici's Avatar
    Jan 2016
    69
    Go directly with win 10.
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    300
    7,440
    Windows 10 should recognize your hardware fingerprint so it will now reinstall directly.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    ROG Member Array
    Mar 2015
    13
    thank u guys ,, it worked
    Ex-employee Array
    Jun 2020
    108
    2,154
    Key is encrypted in secure boot so you never need to type in a key anymore if you installed Windows 10 before on that system.
